Bare Metal
Old Oct 16, 2006 | 11:15 PM
Shifty101Easy's Avatar
Shifty101Easy
Default Bare Metal
i stripped my fender of all paint....and everyone says to fill first then use self etching primer....i now have both but its hard to see all the nicks and dents on the bare meta....what do you guys think about doing the nicks and dents that i can see on the bare metal with filler, then using the etching primer....then if theres anywhere i missed, fill over that??? is that okay to do???
Old Oct 16, 2006 | 11:39 PM
chillininnh's Avatar
chillininnh
Default RE: Bare Metal
I'm sure there is more than one way to do it but if it were my fender I would strip the fender to bare metal then shoot it with a direct to metal epoxy primer sealer. Then you can fill it, block it, and spray it with a high build primer.
Old Oct 16, 2006 | 11:44 PM
Shifty101Easy
ok u gotta help with the primers....epoxy primer is differnt than self etching primer, correct?
Old Oct 16, 2006 | 11:50 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
yes if u use the etch primer ur not supposed to shoot it over filler(it will soak in and not dry properly)
Old Oct 17, 2006 | 12:10 AM
Shifty101Easy
ok so basically im supposed to shoot the etching primer, then fill....then use high build primer...?
Old Oct 17, 2006 | 12:15 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
i would sparay it with two caoats of the self etch (with the propr flast time in between let it flash(check the can then go ahead and spray it with the sandable/high build a few coats remeber the flast time(then i would take some black paint and dust over that as a guide coat then block sand the fender with 180-220 grit paper this will reveal the highs and lows visually then u can go from there if its a bad dent take it to the metal and appy filler if its very shallow u can scuff it up with some 80 grit ,ake sure to do it past the dent so u can feather the filler out
jrrhd73must
Oct 2, 2015 09:17 PM
KingRando
Oct 2, 2015 08:06 AM
UrS4
Sep 30, 2015 10:13 AM
mungodrums
Sep 28, 2015 10:54 PM
mrappe
Sep 26, 2015 10:16 AM
