Kill Switch
Old Jul 31, 2004 | 06:20 AM
68coupe's Avatar
68coupe
Default Kill Switch
Hey all
whats the best way to install a kill switch? I've been thinking of buying one for some time now and i think I'm going to make it this weekend's project.
thanks in advance
Old Jul 31, 2004 | 10:05 PM
67coupe's Avatar
67coupe
Default RE: Kill Switch
If you have electronic ign just interupt the positive wire that comes from the ignition switch to the coil. If you have points you can run a wire from the negative on the coil to the kill switch and then from the kill switch to any ground. When the circuit closes it grounds the coil and you get no spark.
Old Aug 1, 2004 | 12:08 AM
68coupe's Avatar
68coupe
thanks 67
does anyone know how to hook the kill switch up to the starter? ive heard this is a little better than going the coil route, what do you guys think?
thanks again
Old Aug 2, 2004 | 11:14 AM
pichinco's Avatar
pichinco
67coupe has the better idea. You can interupt the electricy to the starter in several ways, but are usually pretty obvoius to someone try to start the car. The coil thing generally is more of a obutse, because it's not obvious what the problem is. The car just acts like it won't start! Whereas if you bypass the starter, the potential theif is going to start looking for a kill switch.
lincolnshibuya
Jul 5, 2020 03:05 AM
PaulH2
20
Jan 31, 2016 09:48 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
Sminemann
Sep 17, 2015 09:24 AM
