69 mach1 upper trunk panel question
Old Oct 21, 2006 | 06:51 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Default RE: 69 mach1 upper trunk panel question
seam sealer
Old Oct 21, 2006 | 09:47 PM
rhill13's Avatar
rhill13
Are you serious? I never considered that. I figured that they wouldn't design a car with only seam sealer keeping water out. I thought there would be some more welding involved.
Old Oct 25, 2006 | 08:52 AM
rhill13's Avatar
rhill13
Norcal troy and Chillininnh, did you use seam sealer on that gap between the panels on you car too?
Old Oct 25, 2006 | 09:55 AM
chillininnh's Avatar
chillininnh
I believe the panel is spot welded in the fold underneath tight to the quarter and requires very little if any seam sealer. I took some pics for you and will post them today.
Old Oct 26, 2006 | 06:33 PM
chillininnh
Here you go, don't know how helpful they will be.
Old Oct 26, 2006 | 08:06 PM
amchief's Avatar
amchief
I'm currently working in that same area, mine is filled with seam sealer also.
FYI, Mine is a 70 Mach1
Old Oct 27, 2006 | 01:09 AM
rhill13's Avatar
rhill13
Thanks a lot for the pics guys. I'm going to compare it with what I've got. I have a hunch that I'm going to have to fabricate some areas for mine to look nearly that good. The previous owner must have hacked the entire up.
pimp2303
Sep 17, 2015 08:45 PM
movielover40
Sep 15, 2015 10:37 AM
FivePointToTheOh
Sep 14, 2015 03:35 PM
MusicCity615
Sep 12, 2015 07:05 AM
angeljoelv
SVT Forums
Sep 10, 2015 09:12 PM
