Painting new sheet metal
Old Oct 27, 2006 | 03:52 PM
68FastbackGT's Avatar
68FastbackGT
Default Painting new sheet metal
I am about to start replacing much of the sheet metal on my 68. I am replacing the inner fender apron under the battery and replacing the floor boards. I have never done this before, so I will need a lot of luck.
My question is; how should I paint these panels? I was thinking about using a self etching primer from Eastwood and then covering it with Eastwood’s Chassis Black paint, but the Chassis Black paint warns that it is not recommended for use over the Self Etching Primer.
Old Oct 27, 2006 | 04:29 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Painting new sheet metal
Some of the Ford Plants used Red Oxide on those panels. Then you can paint them with any paint you want, or just leave them red.
http://www.international-paints.co.u...1&surfaceid=21
Old Oct 27, 2006 | 06:27 PM
coda618's Avatar
coda618
To avoid recurring problems under the battery I would use Por-15 first. Very chemical resistant. Good for the underbody as well. just 2 coats of por-15 and top coat.
Old Oct 27, 2006 | 06:40 PM
THUMPIN455's Avatar
THUMPIN455
I'm gonna use real paint from a gun under the hoods of mine. No more rattle can House of Krylon for my cars.. if you are gonna do it, do it right
jrrhd73must
Oct 2, 2015 09:17 PM
KingRando
Oct 2, 2015 08:06 AM
UrS4
Sep 30, 2015 10:13 AM
mungodrums
Sep 28, 2015 10:54 PM
GLOCKer
Sep 28, 2015 07:36 AM
