Top Dead Center
Old Oct 29, 2006 | 05:32 PM
onuliakattack's Avatar
onuliakattack
Default Top Dead Center
i cranked over the engine by hand so my #1 cylinder is at top dead center but im not sure if its on my power stroke or my exhaust stroke, the rotor is right in between the #8 and #1 cylinder and moving towards my #1. can anyone tell me if im on the power stroke. it seems like the rotor has a long way to go to hit the #1 spot on the rotor. in the picture the bottom white mark is where the rotor is and the #1 is marked just above and to the right.
[IMG]local://upfiles/22269/CE4BDBA1E5F546B3B2E919DEFC1B350D.jpg[/IMG]
Old Oct 29, 2006 | 05:34 PM
FuzzyDiceRule's Avatar
FuzzyDiceRule
Default RE: Top Dead Center
take out the #1 spark plug, and have someone put there thumb over the hole while you crank it, and when you hear the air escape, its on top dead center.
Old Oct 29, 2006 | 05:40 PM
Soaring's Avatar
Soaring
I ♥ Acer
What engine do you have? If it's a windsor, then the #1 will be at 1:00 O'Clock on the dizzy and the rotor will be point at it. If the rotor is pointing at 7:00 0"Clock, it is 180 degrees out. You can also take out the #1 plug and stuff a rag in the hole, then take off the dizzy wire and short over the solenoid to turn over the engine until the rag pops out. Take a screwdriver and put into the #1 plug hole and you will feel if the piston is on top.
Old Oct 29, 2006 | 07:28 PM
valley firearms's Avatar
valley firearms
If it's between 8 and 1 it only seems like a long way. It don't take much. You may be advanced in your timing also and it won't be exactly on #1.
Old Oct 30, 2006 | 03:08 AM
Colorado_Mustang's Avatar
Colorado_Mustang
My Windsor has number 1 at 10o'clock... Where number 1 is depends on if the dizzy's been removed or not. There are 8 holes that can easily accomodate being the number 1 slot...
Use the finger in the spark plug hole method or take off the valve cover. Either will work very well for finding TDC.
ORIGINAL: Soaring
lincolnshibuya
Jul 5, 2020 03:05 AM
Bokeo
Oct 10, 2015 08:28 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
