RUST
Old Oct 29, 2006 | 09:40 PM
mlitz's Avatar
mlitz
Default RUST
so today i decided to take the job of cleaning out my trunk and sanding the rust down ans painting it but on the right side of my trunk it is so bad i'm going to need a chemical! what is the best a remover or a converter and who is the best?
Old Oct 29, 2006 | 10:03 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Default RE: RUST
clean it throughly and get some phosphoric acid to convert it and then top coat it with por15 www.por15.com the stuff can either be brushed or sprayed(if u spray it u have to use there reducer) its comes in a few different color but the gloss black looks kille in the trunk are and can be topcoated with body color if wanted(have to use there tie coat primer in between the two)
Old Oct 29, 2006 | 11:21 PM
mlitz's Avatar
mlitz
Default RE: RUST
were can i get phosphoric acid from? is there a product name?
Old Oct 29, 2006 | 11:36 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Default RE: RUST
ospho is a brand name but its cheaper to just buy the home depot brand its in the house painting section usually just ask the paint person for help
Old Oct 29, 2006 | 11:42 PM
mlitz's Avatar
mlitz
Default RE: RUST
is thid what i need to buy? and how much of it
http://www.por15.com/PRODUCTS/PRIMER...9/Default.aspx
Old Oct 30, 2006 | 12:51 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Default RE: RUST
id go for 2 quarts ull be using this stuff on everything(suspension, engine compartment,engine brackets etc for a tuff long lasting repair) makes it look new and professionally restored if u use it anywhere daylight will get to it then u need to use one of the top coats over it(doesnt make it less effective just makes it change colors)
Old Oct 30, 2006 | 01:30 AM
david01130's Avatar
david01130
Default RE: RUST
If you are a welder guy or know someone who eill do it for you the best way would be to replace the metal all together. If not, make sure you grind it down very well. Try to get all the black rust spots out by grinding down hard. Then put rust remover on. Make sure you dont pour the stuff on or it will come out all gummy. do about 2-3 thin layers depending on what product you use.
Old Oct 30, 2006 | 08:24 AM
chillininnh's Avatar
chillininnh
Default RE: RUST
Eastwood makes a Rust Encapsalator which is supposed to be superior to Por 15. These guys sell just about everyting you will ever need to restore a classic mustang body.
http://www.eastwoodco.com/
They also have an online forum to help answer your questions.
Old Oct 30, 2006 | 11:24 AM
MC's Avatar
MC
Default RE: RUST
ORIGINAL: chillininnh
[sm=exactly.gif]
GPR
Dec 16, 2015 12:21 PM
b8checker
Oct 8, 2015 12:55 PM
b8checker
Sep 30, 2015 07:11 AM
Sep 17, 2015 07:57 PM
showoffzx2
4 Cylinder NA and Turbo
Sep 14, 2015 08:40 PM
