Creaks from trunk
Old Nov 8, 2006 | 09:44 PM
The stang II's Avatar
The stang II
Default Creaks from trunk
Ok my Mustang II creaks alot in my trunk. It only happens when I go over bumps and turn a sharp corner. We put new weatherstripping in and that quieted it up, then I got rear ended (but no damage to my car) then the creaking happened again. I do not see light through the hatch though so it's still hitting the weather stripping, but i don't know why it creaks.
What should I do or check for? How do I check for exactly where the creaks and cracks are coming from?
Thanks.
Old Nov 8, 2006 | 10:41 PM
Toddman0025's Avatar
Toddman0025
Default RE: Creaks from trunk
I have a similar problem, I always figured it was the rear suspension...
Old Nov 8, 2006 | 11:12 PM
Halz5's Avatar
Halz5
i would assume the suspension, could be rubbing on something, possibly a bad bushing?
Old Nov 8, 2006 | 11:14 PM
66 stang's Avatar
66 stang
i bet its your rear end or suspension, take a look at it, and have someone push down on the car a lot
Old Nov 8, 2006 | 11:21 PM
Scott H.'s Avatar
Scott H.
Are you running any polyurethane bushings in your rear springs or Shackles? If so, pick up some proper grease, and lube the heck out of them.
Is your spare full of air and tight? How about the jack stuff?
You might look for signs of rust trails that would indicate a broken weld(s). I've gone so far as to spray the whole rear chassis with black paint, then driving the heck out of it for a week or so. When I went back under, I could see where the paint flaked off, or cracked. That was where the loose panel was.
Good luck,
Old Nov 8, 2006 | 11:39 PM
andrewmp6's Avatar
andrewmp6
have someone jump up and down on the back of it see if you can hear about where its coming
Old Nov 9, 2006 | 02:07 AM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
how old are the leaf springs they might be rough i had this prob on my 77 f250 i put wd-40 all over the leafs and haven't had a prob since
Old Nov 9, 2006 | 02:30 AM
The stang II
Damn! Haha. Well where to start... We replaced the shocks, but leaf springs no. I noticed something creaking on my right side rear tire creaking like the axle but it's not something I could hear in the car.
I will have someone push down and see or hear where it's coming from. I think my hatch is lose because it's creaking all around the hatch.
I will see if my spare tire is lose and those things.
But do all old cars creak or are really loud when you go over a bump on a road because I can feel and hear my whole car shake when I hit a pot hole or anything. But I just ignore it because I know it's an old car and they do somet times creak.
Thanks with all the help guys! I will take all your info and check it out because I will find out why it's doing it.
flash_xx
Sep 21, 2015 01:25 PM
pimp2303
Sep 17, 2015 08:45 PM
movielover40
Sep 15, 2015 10:37 AM
robjh22
Suspension
Sep 8, 2015 12:47 PM
MustangJourney
Sep 2, 2015 04:32 PM
