what CFM?
Old Nov 11, 2006 | 07:45 PM
stangman67's Avatar
stangman67
Default what CFM?
what is the best CFM carburator for a 302 that is pretty much stock?
Old Nov 11, 2006 | 07:47 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Default RE: what CFM?
500-600 would be enough.
cfm=(cid*rpm)/3456
Old Nov 11, 2006 | 07:49 PM
stangimgood's Avatar
stangimgood
[sm=exactly.gif] i agree
Old Nov 12, 2006 | 12:11 AM
Soaring's Avatar
Soaring
I ♥ Acer
Yeah, 500-600 IF we are talking about a 4V carb. You didn't specify.
Old Nov 12, 2006 | 02:02 AM
Halz5's Avatar
Halz5
ORIGINAL: Colorado_Mustang
cfm=(cid*rpm)/3456
i dont like that formula, lol makes me sound stupid to have a 750cfm on my 350 lol
Old Nov 12, 2006 | 04:46 AM
Colorado_Mustang
Works good with 7000+ rpm...
ORIGINAL: Halz5
cfm=(cid*rpm)/3456
Old Nov 12, 2006 | 05:43 AM
Lumbergh's Avatar
Lumbergh
ORIGINAL: Halz5
cfm=(cid*rpm)/3456
It also depends on other modifications to the engine. IMO 750 would be too much for a stock 350, but I've seen modified 302s (more aggressive cams, etc) running great with 650 CFM four barrels.
For a stock 302, though, I would think 500 cfm would be good and 600 would be overkill. And, if your going to increase the flow on one end of your engine, intake and carb (you are doing the intake as well, aren't you?), you're going to need to modify the exhaust as well. Just something to keep in mind.
Old Nov 12, 2006 | 05:50 AM
Halz5's Avatar
Halz5
ORIGINAL: Lumbergh
ORIGINAL: Halz5
cfm=(cid*rpm)/3456
well on my 350... i got an edelbrock performer 750cfm with a performer intake, .450something lift, 9.5:1 comp, headers, hei with msd 6a....think thats about it... anyway it has a killer bog since i switched carbs but i'm not flooding... thinking maybe vacuum or the choke... since its 30 degrees out i cant really test much.
put the 600 from the 350 on the 302... dont know anything about the 302. but it ran like a champ... was very impressed
Old Nov 12, 2006 | 05:26 PM
Colorado_Mustang
Some of your bog may be from the size of the venturi. If you can, slow down the linkage that activates the throttle (move the point it connects higher on the arm). Accelerator pump tuning and possibly metering block changes may help, too.
My 302 loves its 650...as long as I keep it above 2k.
LiquidDrink
Sep 29, 2015 10:06 AM
Philhampton1
Aug 21, 2015 12:04 PM
kevs66coupe
Feb 19, 2004 04:09 PM
TheGmKiller331
Feb 16, 2004 07:21 AM
AllTheTime
Sep 3, 2003 02:25 AM
