top loader
Old Nov 14, 2006 | 12:49 PM
jacklambert's Avatar
jacklambert
Default top loader
how much power can a toploader 4sp handle? i am concidering nitrous. has probably 500hp flywheel already.
Old Nov 14, 2006 | 02:43 PM
85lebaront2's Avatar
85lebaront2
Default RE: top loader
A friend used to drag race one in a 1964 Galaxie (4000 lbs) with a 427 medium riser turning in the mid 12s. He broke the input shaft and went to the NASCAR input shaft, then he broke the output and went to the NASCAR output. He then managed to break a 9" pinion. He was probably making 7-800hp., but gobs of torque. You can break anything, another friend wrung the output shaft on his 1970 Torino CJ when he ran it so low on oil it welded the third gear to the shaft and broke it. They are one of the ruggedest car transmissions going with maybe the Mopar 4 speed a close rival. It will take a whole lot more than a Borg-Warner or Muncie.
Old Nov 14, 2006 | 04:32 PM
bronco1's Avatar
bronco1
I wouldn't be a bit afraid to hook up 500HP to a Toploader...big time heavy-duty.
Old Nov 16, 2006 | 04:47 PM
scott_m_mil's Avatar
scott_m_mil
Toploaders are nearly indestructible now 7-800 horse power is a bit much. But 500 should be no problem at all.
lincolnshibuya
Jul 5, 2020 03:05 AM
chrisdbassplayer
Oct 13, 2015 06:53 PM
Bokeo
Oct 10, 2015 08:28 PM
b8checker
Oct 8, 2015 12:55 PM
jc409
Convertible Tech
Sep 26, 2015 08:28 AM
