Rack & Pinion
Old Aug 26, 2004 | 06:13 PM
69mach1377's Avatar
69mach1377
Default Rack & Pinion
Anyone install the new Flaming River rack and pinion kit into their classic stang yet?
Old Aug 26, 2004 | 06:33 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
Default RE: Rack & Pinion
Why not just put a stock manual rack in? Im sure that was a factory option that year, unlike the newer stangs which is why the kit was produced
Old Aug 27, 2004 | 03:47 PM
69mach1377's Avatar
69mach1377
There was no stock rack in 1969, just the gearbox and linkage type, with a 'rag joint' in between that and the steering column shaft. Stuff gets old and loose....
Old Sep 3, 2004 | 03:38 PM
69mach1377's Avatar
69mach1377
Okay, since nobody bit...I am in the process of installing the flaming river R&P kit designed for headers on a small block. Guess what? It doesn't fit...the pinion shaft ended up a half inch away from one header pipe and dead smack in the middle. No room for the U-joint. They offer a big block kit that lowers the rack by 3 inches, no guarantee to fix my problem, but guaranteed to reduce ground clearance by 3 inches! I'm not bashing them, just wanted to let others know of potential challenges. Fortunately, my bro-in-law offered to mod the header tube by rerouting it outboard, this weekend. I hope it works, cause it looks like a sweet package. All that old wiggly stuff replaced by a modern lightweight setup that includes a tilt column!
Old Sep 12, 2004 | 12:16 PM
69mach1377's Avatar
69mach1377
Update; successful installation and alignment. First drive? Awesome, no play in steering wheel whatsover. Not cheap or easy, but highly recommended!
Old Sep 15, 2004 | 09:00 PM
69mach1377's Avatar
69mach1377
Final update, I hope. Earlier I said I wasn't bashing Flaming River...but now after spending more time and money to make the kit fit, that should have fit, that I paid extra for so it would fit...they won't refund the difference on the left over parts that were supposed to make it fit. Got that? I have useless parts and and extra bill because their stuff did not work as advertised. Buyer beware! They sell you stuff you don't need and don't refund the difference on the parts you did not use or even open, and their stuff is not bolt in as advertised...I am bashing them for sure.[:@]
mtgldr
Feb 3, 2024 09:00 PM
baddog671
Jul 26, 2016 01:20 PM
KingRando
Oct 2, 2015 08:06 AM
allenmaty
Sep 24, 2015 09:17 AM
Blk Vert
Sep 9, 2015 12:16 PM
