Trunk Paint
Old Dec 2, 2006 | 09:29 PM
rlbjrcpa's Avatar
rlbjrcpa
Default Trunk Paint
I was cleaning the trunk interior on my 65 fastback and noticed some small areas with a little surface rust so decided to prime and repaint the interior. Will a standard primer prevent this rust from spreading? Any advice on type/brand of paint? Thanks.
Old Dec 2, 2006 | 09:47 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Default RE: Trunk Paint
primer it by itself absorb water so if u left it open then no it will slow it, now if u cleaned all the rust so it was nice clean metal primed, and top coated then ull be good for a long time
Old Dec 2, 2006 | 10:03 PM
Soaring's Avatar
Soaring
I ♥ Acer
Pick a day where the weather is dry. Take everything out of the trunk and vacuum it out. Brush some rust encapsulator (POR 15 for example) on all the metal in the trunk. Let that dry completely, then hit it with primer. Let that dry completely, then hit it with color.
Old Dec 3, 2006 | 03:53 AM
Lumbergh's Avatar
Lumbergh
ORIGINAL: Soaring
+1
Old Dec 3, 2006 | 04:10 PM
rlbjrcpa's Avatar
rlbjrcpa
got it - thanks for the advice.
Old Dec 4, 2006 | 01:23 AM
baddog671's Avatar
baddog671
I completly stripped and prepped my trunk about half a year ago. I will post some pictures for you tomorrow if you like. I used painter stripper, then sanded it down the best i could and hit it with normal primer. I still need to get some seam sealer on it and then Im going to Dynamat the whole thing. Goodluck!
Oct 1, 2015 09:29 AM
mungodrums
Sep 28, 2015 10:54 PM
GLOCKer
Sep 28, 2015 07:36 AM
movielover40
Sep 15, 2015 10:37 AM
mustangchef
Sep 4, 2015 08:08 PM
