one piece floor pan
I simply welded it in, welders dont usually care about a trace of oil, but paint does. before I spray it, there will be a degreaser, and plenty of solvent used to clean the thing before any primer, filler, or color touches it.
I dont want to have fisheyes on the floor...lol.
Yea I know about prep, I sell paint to OEMs. What about the old paint on the original, do I need to remove that before welding?
ORIGINAL: THUMPIN455
ORIGINAL: rmodel65
i think you could probably fanagel it up inside from underneath if u went at an angle
ACADIST
You dont want to have a bunch of dirt, rust and paint residue where you are welding, it makes for a cleaner weld if its clean metal on metal. You start fewer fires that way too..
You can weld through paint if you need to, but I would rather clean the joints good to be sure there is no rust causing stuff between the parts. Cleaner is always better, and you need a good ground source to weld, otherwise no arc will take place.Thread
door, floor, floorpan, ford, installation, manufactures, mustang, pan, pans, peice, piece, trough, versus, welding, windshield
