brake light problem solved - update
Old Dec 26, 2006 | 06:22 PM
jroseman's Avatar
jroseman
Default brake light problem solved - update
my left turn signal would notclick off after a turn so i decided to change the turn signal cam. i ordered one from mustangs unlimited. when i put the new ts cam in, it did not fitproperly so i had to do a little trimming. i finally got it in and everything worked fine - for a short time. i soon discovered that i had no left brake light. i went back in and tested everything. i called my local supplier and she said that the aftermarket cams never fit and although she sold them, would advise me to buy the whole turn signal - horn wiring harness. $75. i really had no choice as i had played with the new - old cam for over two days, trying to adjust it. i could get it working for a little while but it would always revert to its old tricks.
i put in the new wiring harness and hooked it up - took about 45 minutes - and everything works fine.
i know some of you will tell me i did not need the new harness - but believe me - i tried everything else and it just wouldn't work. if i ever have the same problem, i won't mess with putting in a cam, i will replace everything again.
Old Dec 27, 2006 | 12:09 AM
moparmatt89's Avatar
moparmatt89
Default RE: brake light problem solved - update
I went through the same thing. I thought that just replacing the turnsignal cam would fix it, but I just couldnt get it to fit right either, and when i finally did, it still didnt work. I just spent the 75 bucks for a new one and it was well worth it. I totally agree, dont waste time with the little parts in it, just get the whole new turn signal!
Old Dec 27, 2006 | 05:42 AM
symbiote's Avatar
symbiote
is this a similiar problem to when the left light indicator light on the dashboard refuses to work but the rest of them do? that is what is happening to me....its retardd..but it comes back on when it feels like...i think its linked to this other problem im having.....when i push the emergency flasher button both lights stay on....no blinking..just stay ON!!....
Old Dec 27, 2006 | 10:36 AM
restomod66's Avatar
restomod66
Check the flasher relay under the dash it could be shot.
Old Dec 27, 2006 | 11:42 AM
symbiote's Avatar
symbiote
hmm...ok...where is the relay exactly? Could you upload a picture or something? thanks
Old Aug 29, 2007 | 09:49 PM
thebaldguy's Avatar
thebaldguy
RESOLVED - OLD CAR ELECTRICAL GREMLINS AND FEW SIMPLE PARTS - Stop lamp switch, hazards relay, few grounding concern,s poor connections. Old post, but experiencing a related problem on a 72 Mach 1 351C-2V. My hazards remain on, not blinking. At the same time I have NO brake lights EVER. Looked underneath one wire goes to wire bundle (assuming to fuse) and second goes the relay mentioned by restomod66 posting. Anyone believe the brake lights could also not be functioning because of this relay? I did have a number of shorts, burnt out bulbs throughout the car when I bought it but thought i have addressed those issues. Haven't picked up a wiring diagram yet as have only had the car two weeks. Appreciate any thoughts/insight..
JonnyBlazeGT
Nov 3, 2015 01:10 AM
bond007
Aug 26, 2015 11:36 PM
kdryan
Aug 21, 2015 04:01 PM
cody.hoeppner
Aug 12, 2015 06:39 AM
cody.hoeppner
Aug 11, 2015 08:08 PM
