Power steering pump replacement
Old Dec 26, 2006 | 09:10 PM
fireball's Avatar
fireball
Default Power steering pump replacement
Mustang Experts,
I am replacing the power steering pump on my '65. The part I recieved from the parts store looks good, except for the return spout. On the original pump the spout points down, and on the replacement pump it points up. How the heck I am supposed to hook up the return line? Is this normal? Should I lengthen the return line?
Old Dec 26, 2006 | 11:32 PM
sxs191's Avatar
sxs191
Default RE: Power steering pump replacement
There are two differen't power steering pumps to choose from...with AC or without. The pump WITHOUT AC points up . The pump WITH AC (you guessed it) points down.It appears you might have gotten the wrong pump if your 65 has AC.
Old Dec 27, 2006 | 03:41 AM
stanger53's Avatar
stanger53
Sorry to disagree with the post above, but the return hose nipples were not different between AC and non-AC cars, just the angle of the filler necks. All Mustang 1965-1966 V8 pumps had downward pointing return hose nipples. That's why the return hoses were the same regardless of AC or non-AC.
If the rest of the pump looks correct, but the return hose nipple points upwards toward the top of the fender apron, instead of downward toward the frame rail, the pump is for a Galaxy. An OEM style return hose will be too short and will kink. Better to add an extension to the hose so this doesn't happen.
It probably won't be just a simple matter of swapping the cans from a Mustang pump to the rebuilt you got. On some Galaxy pumps, the location and clocking of the holes in the back of the can are different from a Mustang.
djbigskrilla
Sep 20, 2022 01:04 AM
Design1795
Jan 24, 2017 10:38 PM
Cit95
Sep 22, 2015 07:08 AM
Design1795
Aug 24, 2015 04:41 PM
drumhedd2005
Aug 13, 2015 09:59 AM
