boss 302 clone
Old Jan 2, 2007 | 06:58 PM
ih8chevy's Avatar
ih8chevy
Default boss 302 clone
has anyone ever built this motor, a windsor style 302 block with cleve heads
i read that with just the cleve heads they make 400 hp
was wondering if this is true and how easy it would be to build
Old Jan 2, 2007 | 07:51 PM
JamesW's Avatar
JamesW
Default RE: boss 302 clone
There's more to it than just sticking Cleveland heads on a Winsor block. The water passages have to be modified in the heads and I think intake. It's nota simplemod.... or there'd be a bunch of people doing it!
Old Jan 2, 2007 | 07:59 PM
my77stang's Avatar
my77stang
its not that hard you just need the info to make it possible. one thing i remember is on the deck surface of the heads there is a square water port on the cleve's that needs to be drilled to a 1" hole and a freeze plug installed... you'll need an intake from a boss - there was a company making aftermarket ones but i forget the name. honestly the cleveland 4bbl heads are too much for a 302, and the cleve 2bbl heads have HUGE chambers which just kills compression unless your running forced induction.
solution? australian cleveland heads have 2bbl ports and 4bbl chambers which makes for best streetability on a 302 OR you can build a 351w (or 351w based stroker) and use this http://www.pricemotorsport.com/html/...apter_kit.html
along with a boss 302 / aftermarket intake and the clevey 4bbl heads
Old Jan 2, 2007 | 08:13 PM
middiepride's Avatar
middiepride
check this place out. they are building crazy heasds and the intake to match. they are only a hundred more than a set of afr's
http://www.chiheads.com/index.php
Old Jan 2, 2007 | 08:30 PM
ih8chevy's Avatar
ih8chevy
well first off i kno about hte water passages and hte coolant passages but i was wondering if anyone has done it i see them on ebay and they say with a stock 302 block and 2v cleve heads they are making 400 hp and i was thinkin about doin it but its very hard i kno, so i was wondering if u thought for that motor 3000 was too much to pay for it heres the link
http://cgi.ebay.com/ebaymotors/400-h...019QQitemZ2900
65630099QQrdZ1QQsspagenameZWDVW
Old Jan 2, 2007 | 08:31 PM
ih8chevy's Avatar
ih8chevy
also what does it take to fit the 351w to the 4v cleve heads
Old Jan 2, 2007 | 09:14 PM
69mach1377's Avatar
69mach1377
4v or 2v takes the same effort on a 302 or 351 or 377 in my case. Ford motorsport had how to directions. Back when this mod started in the aftermarket, say 10+ years ago, it was the bomb because the there weren't very many aftermarket heads for the small blocks and the C heads flowed pretty good. Nowadays, you have many aluminum heads to choose from, so do so is my advice...
Old Jan 2, 2007 | 10:52 PM
my77stang's Avatar
my77stang
to use a 351w and the cleveland heads you need this:
Old Jan 3, 2007 | 02:33 AM
ih8chevy's Avatar
ih8chevy
stil what do u guys think of hte ebay ad i posted with the motor
Old Jan 3, 2007 | 03:47 AM
atomsk680's Avatar
atomsk680
you know i saw a ad for a boss 302 shortblock remake, its kinda pricey but its should be available now
