Need help metal works
Old Jan 4, 2007 | 01:38 AM
green_blurr's Avatar
green_blurr
Default Need help metal works
2 questions how do i get the remaing radiator supportoff cleanly from the front support? i got most of it off with a torch
How should i go about patching these small holes in the dash? that hacked hole in the dash is covered up by a radio faceplate btw
[IMG]local://upfiles/43944/04FF9027A7A340CA87F461F2B1F0048F.jpg[/IMG]
[IMG]local://upfiles/43944/FD73475229F642DA931290873365932E.jpg[/IMG]
[IMG]local://upfiles/43944/024967EBA19E41BDB2DF9C4C314B5878.jpg[/IMG]
Old Jan 4, 2007 | 01:56 AM
bronco1's Avatar
bronco1
Default RE: Need help metal works
Grab the grinder...it takes some time, but is pretty clean. You may want to cover those hoses up first though...
Old Jan 4, 2007 | 02:07 AM
green_blurr
thats alot of metal to grind though the radiator support is tack welded to that front frame
Old Jan 4, 2007 | 02:13 AM
atomsk680's Avatar
atomsk680
sawzall FTW!!!!!!!
please dont take that seriously[]
Old Jan 4, 2007 | 02:19 AM
green_blurr
Thats no help there is nothing to saw !!!!
Old Jan 4, 2007 | 02:28 AM
bronco1's Avatar
bronco1
I understand about the amount of metal...but short of a plasma-cutter, that would be the cleanest. If I remember right, there are too many spot-welds in that area to try to pick them out and drill them...not to mention structural integrity if you drill through...[:@]
Old Jan 4, 2007 | 02:33 PM
THUMPIN455's Avatar
THUMPIN455
I use an air chisel to seperate factory spot welds like that. They arent too expensive and you will find they work for a bunch of diferent tasks. You dont need a huge air compressor to run them either, just be sure to wear gloves and eye protection while using it. I have caught cars on fire with grinders, cutters, torches and other flame/spark creating devices, so I tend to use my air chisel alot. Its a cheapie I got from Menards..lol.. it works okay too.
Be carefull and go slow, you dont need to rip right through everything on the first cut, take small bites and you will find you can be very accurate with it.
Or just keep grinding...
Here is one Summit has..
http://store.summitracing.com/partde...p;autoview=sku
Mobiusone stang
Sep 7, 2015 08:46 PM
mustangchef
Sep 4, 2015 08:08 PM
cbird1177711
Sep 3, 2015 08:43 PM
Sep 1, 2015 08:16 PM
