289 4V Question
Old Jan 6, 2007 | 10:38 PM
MrMainEvent24's Avatar
MrMainEvent24
Default 289 4V Question
Can any of you guys explain how the 289 4V worked off of 1 camshaft. Todays cars with 4 valves per cylinder use two cams. Can you guys explain how one camshaft could open all of those valves?
Old Jan 6, 2007 | 10:42 PM
Yonco's Avatar
Yonco
Default RE: 289 4V Question
The4v Stands for 4 ventri, which basicly says its a 4 barrel carb. Its still a 2 valve per cyl heads, the 4v just stands for something completly different. I was confused about this a few weeks ago tuill colorado explained it to me! -Jon
Old Jan 6, 2007 | 10:45 PM
Bulldog66's Avatar
Bulldog66
Well sonny, back when I was young, we only had money for one cam. We'd just time it right and have it open the needed vale pending what stroke it was on. All you young whipper snappers are so spoiled on your new fancy hot rods and all your 4 cams!
On a serious note - it's the same as it always has been for a one cam, push rod motor. The lobe of the cam opens and closes the valves in time, pending what stroke.
Simple 4 stroke operation.
EDIT* d'oh - misread the question. See, old age gets you in teh worst spot
Old Jan 6, 2007 | 10:57 PM
my77stang's Avatar
my77stang
lmao @ whipper snapper
Old Jan 7, 2007 | 12:42 AM
JamesW's Avatar
JamesW
http://auto.howstuffworks.com/camshaft.htm
Go to the Pushrod section.
Old Jan 7, 2007 | 12:59 AM
6mustang6's Avatar
6mustang6
Yep, still 2v heads. I sure wish they had 4 valve heads. that would be awesome.
Old Jan 7, 2007 | 01:48 AM
Colorado_Mustang's Avatar
Colorado_Mustang
There were kits to convert the 5.0L to OHC and another to convert it to 4-valve per cylinder. They had some funky looking rocker arms as the 4-valver still used the same cam.
As you would expect, these kits were a bit more expensive than most engines, let alone heads. I'm thinking somewhere around 5-6k.
Old Jan 7, 2007 | 10:12 PM
MrMainEvent24
What does the ventri mean then?
What makes the 289 4V better than the regular 289?
Old Jan 7, 2007 | 10:21 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: MrMainEvent24
If you look down into a carburetor, you will see either 1, 2 or 4 holes that go into the intake. Those holes are called venturis. So a 2v carb has two holes, and a 4v carb has four holes. The difference being that the 4v carb has an added link in the acclerator that opens what are called secondaries to allow more fuel and air to enter the combustion chamber so you get more detonation causing more power from the engine. The C code Mustangs had a 2v carburetor, and the A and K code engines had the 4v carburetor. Actually, Venturi was a real dude.
carburetor air inlet:a restricted air inlet in a carburetor that produces a drop in pressure, causing fuel vapor to be drawn out of the carburetor bowl
[Late 19th century. After Giovanni Battista Venturi (1746-1822), Italian physicist]
Old Jan 8, 2007 | 09:50 AM
MrMainEvent24
thanks for the info, i appreciate it.
While we are on the topic of the 289 4V, what are some good ways to add power to this motor (1964.5), keeping in mind that i want it to be as original as possible? Are this easy ways to bolt on a couple things to make this motor a beast?
ding56
Aug 14, 2015 02:40 AM
asko98
Feb 7, 2006 04:12 AM
asko98
Jan 22, 2006 12:43 PM
akgage
Dec 28, 2005 12:33 AM
akgage
Dec 27, 2005 11:38 AM
