Evans waterless coolant
Old Jan 7, 2007 | 03:37 AM
valley firearms's Avatar
valley firearms
Default Evans waterless coolant
Has anyone ever tried this coolant?
http://www.lubricationspecialist.com...978a1f8b4af3ce
Old Jan 7, 2007 | 03:40 AM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
Default RE: Evans waterless coolant
sounds cool but when its 9.99 i will buy it
Old Jan 7, 2007 | 05:49 AM
Colorado_Mustang's Avatar
Colorado_Mustang
Looks good. I'd ask for warranty just in case it does cause a problem. I doubt it will, though.
I would wonder if it's compatible with existing coolant, since getting all the coolant out of an existing system is near impossible.
Old Jan 7, 2007 | 06:37 AM
enzedchris's Avatar
enzedchris
i would be cautious. firstly because i have never heard of it, which doens't make it bad, but hmmm. i would wonder about the viscosity, how corrosive their product is even though it says will cure corrosion. but is there any need to switch your coolant brand- i mean don't fix anything unless it's broken, or else you would turn into a german engineer you know what i mean.
Old Jan 7, 2007 | 12:22 PM
Soaring's Avatar
Soaring
I ♥ Acer
Everything I have read says that pure water cools better than any coolant. I would question this product, and especially since it is over 30 bux a gallon.
Old Jan 7, 2007 | 12:26 PM
baxsom's Avatar
baxsom
ORIGINAL: Soaring
i know when i get my motorcycle track ready i drain coolant and replace with pure distilled water and redlines water wetter,
temps drop over norm by almost 10 degrees
Old Jan 7, 2007 | 01:28 PM
Brandontyler65
I ♥ Acer
water wetter is awesome
Old Jan 7, 2007 | 07:23 PM
ponyx2's Avatar
ponyx2
In a word...snake oil.
Old Jan 8, 2007 | 03:37 AM
valley firearms
It says it will mix with antifreeze. The only good thing I see from this is no overheating. The stuff won't boil. If you had a overheating problem this may cure it.
[align=left] [/align]
Granatelli Sales
Jan 20, 2020 12:34 AM
Nick Oliver
Oct 17, 2018 04:22 AM
wraith777
Sep 28, 2015 10:49 AM
Sep 16, 2015 07:53 PM
MusicCity615
Sep 12, 2015 07:05 AM
