Tires?
Old Jan 10, 2007 | 04:19 AM
Colorado_Mustang's Avatar
Colorado_Mustang
Default RE: Tires?
I liked my BFG Radial TA's.
Old Jan 10, 2007 | 06:23 AM
Bulldog66's Avatar
Bulldog66
Default RE: Tires?
I'm satisfied with my Dayton tires. They are soft enough that I can get a little heavy footed in corners and still hard enough for me to smoke'em if needed.
I am not a big fan of Firestone after the tire issues from 99'. We had an Explorer that had a set of the bad tires and when we contacted Firestone, they just said too bad. Even the dealership we got the truck from replaced the tires free of charge becuase the side walls were splitting.
I'm sure all of that is corrected by now, but I still have that sour taste from dealing with them directly. I'd of even met them half way to replace them,. but they basicaly shut the door on me so now I'll never purchase a damn thing from them.
Old Jan 10, 2007 | 10:20 AM
coda618's Avatar
coda618
Default RE: Tires?
+1 on the BFG RTA's 215/70/14 on my 67. Prob not the best size for performance applications, but looks good on the car and handles well for me. Also, at about $85 each, good bang for the buck.
I just can't seem to get my arms around tthe idea of Pirelli, Yokohama (?) or Toyo etc. tires on a classic Made in the Good 'Ol USA Classic. Just doesn't seam natural to me.Buy USA. I know its not possible in all situations, but there are certainly qualityUS made tires out there that will suit your needs. Sorry for the rant, just my little hangup.
Good luck.
Old Jan 10, 2007 | 10:27 AM
P Zero's Avatar
P Zero
Default RE: Tires?
BFG RADIAL T/A'S ARE NOT SPEED RATED ABOVE 112. Neither is the cooper cobra or the goodyear GTII. If you plan on racing and there is even a remote chance of you going over 112, youll need AT LEAST an H rated tire. H is good till 129 (unless they changed the ratings again[:@]). Personally, I wont run anything lower than a Z UNLIMITED or sub class of Z (W,Y). But hey its your ***, if you trust your tires to hold up at speeds theyre not rated to go, itll be your own damn fault when they blow and you wreck.
-P.
Old Jan 10, 2007 | 10:30 PM
restomod66's Avatar
restomod66
Default RE: Tires?
I don't think I'll be traveling at speeds of 112 mph in my old classic. No need for it to get loose and put her into a wall!! It is a cruisen mobile that enjoys a little squeaking of the tires at times!!
Old Jan 10, 2007 | 10:40 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Tires?
ORIGINAL: restomod66
Heard that. We don't need Z rated tires for our classics. If I ever get over 70 MPH, I have more problems than the tires are causing me.
LCC's Avatar
LCC
Default RE: Tires?
BFG "G force" They work very well and look amazing
Old Jan 10, 2007 | 10:53 PM
Colorado_Mustang
Default RE: Tires?
Anyone else see the humor in this post?[sm=laughat.gif]
ORIGINAL: Bulldog66
Answer.
I've always gotten a kick about this whole tire ordeal. The problem wasn't entirely the tires, it was primarily the idiotic and/or lazy auto owner that had much better things to do than check their tire pressure every once in a while.
Old Jan 10, 2007 | 11:50 PM
hondakilla's Avatar
hondakilla
Default RE: Tires?
Thanks guys. I think I might try the BFG's. Will they be reliable over 100 mph though?
Old Jan 11, 2007 | 01:27 AM
19stang66's Avatar
19stang66
Default RE: Tires?
I'm running Sumitomo HTRZ II's all around and I think they are great so far. Not a whole lot of miles on them though. They are pretty inexpensive also, I think I paid $90 each. Go to www.tirerack.com and look at the tire you want. They have a lot of info about each tire and what they are made for. There are also customer reviews/comments.
