surface prep for body filer?
I am going to remove the paint on the dash the previous ownerdid not spray on a primer on the dash which is why the paint chipped. My question is when applying body filler to bare metal such as a dash panel to cover small holes and even surfaces out, what grade of sandpaper should be used on the metal to prep so it adheres to the metal ?
180 is the finest you can use, and I wouldnt go much rougher than 80. You dont want deep gouges. Rough out the shape of the filler with 80, and finnish it with 220-400 grit. You want the smallest sanding marks possible, then prime it and sand with 400 and up.
Oct 1, 2015 09:29 AM
