Vacuum advance.
Old Jan 9, 2007 | 02:46 PM
sxs191's Avatar
sxs191
Default Vacuum advance.
Dumb question coming...... Is the Single distributor vacuum advace for single point distributors and like wise for the dual? And what does it do anyways? Thanks.....
Knowledge is Power and as you can tell, I have no power....
Old Jan 9, 2007 | 03:03 PM
Lumbergh's Avatar
Lumbergh
Default RE: Vacuum advance.
I'm not sure I understand your first question. Vacuum advance advances the timing-by rotating the distributor slightly)based on the engine load. There is also centrifugal advance which advances the timing based on engine speed. Asthe enginespeed or the load that you are putting on the engine increases, you need to rotate the distributor a little so that the spark plugs still fire at the correct time. You can find a good explanation of how an engine's ignition system works including pictures at "How Stuff Works."
Old Jan 9, 2007 | 03:12 PM
sxs191's Avatar
sxs191
Thanks. I want to replace the Distributor Vaccum Advance on my distributor and vacuum hosesbut I can choose either single or dual set up. I had a single point distributor (now changed to Pertronix) so I'm thinking I need the single vaccum advace set up. Hope that helps.
Old Jan 9, 2007 | 03:28 PM
my77stang's Avatar
my77stang
doesnt matter if you have single points, dual points, or electronic ignition - a dizzy that has a vaccum advance will only have one vaccum advance.
Old Jan 9, 2007 | 03:42 PM
OhioMachIRunner69's Avatar
OhioMachIRunner69
+1 on my77stang's comments. If your vacuum advance is just old and nasty looking and is still working fine you can buy a chrome cover that goes over top of the old one for only $4 from YearOne.
Old Jan 9, 2007 | 03:54 PM
sxs191's Avatar
sxs191
I can buy a chrome cover that can go over this?
Old Jan 9, 2007 | 04:01 PM
OhioMachIRunner69
Yup...part #TD4973 at YearOne...its a TD Performance vacuum advance cover.
Old Jan 9, 2007 | 04:06 PM
sxs191's Avatar
sxs191
Thanks, I was just searching in their book for it.
Old Jan 9, 2007 | 06:03 PM
my77stang's Avatar
my77stang
heck, just replace it with a new piece, you can get an adjustable one for pretty cheap.
something along the lines of this:
http://www.cranecams.com/?show=brows...Number=99607-1
im sure accel makes them, as well as a few other companies. those diaphrams do get dry rotted after a certain number of years ya know?
Old Jan 9, 2007 | 06:10 PM
69FECoupe's Avatar
69FECoupe
Your single point distributor could have been equipped with either the single connection vacuum advance unit or the double connection advance/retard unit. What is on it now? If you currently have a dual unit and don't care about originality you can eliminate the retard connection and replacethedual with a single.
mrtrodonet
Sep 19, 2020 03:12 PM
baddog671
Jul 26, 2016 01:20 PM
marc954
Sep 29, 2015 03:05 PM
marc954
Sep 29, 2015 11:18 AM
TfcCDR
Sep 14, 2015 12:08 PM
