Hipo?
Old Jan 13, 2007 | 01:25 AM
6mustang6's Avatar
6mustang6
Default Hipo?
I know a guy selling a Hipo block, cam, heads, and a shelby intake. I know he's selling the block and heads for 400-500, and i dont know about the other parts. Should i consider buying them if they're real hipo parts? Also, I do i know there the real deal? I know the Heads have screw in studs(can you just look and tell) and the block has bigger something right? Thanks guys.
Old Jan 13, 2007 | 01:28 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Default RE: Hipo?
a little wider4 main caps but the block is other wise the same as a 2v 289 the head will have screw in studs and machined valve seats other than that its identical to the 2892v-4v
Old Jan 13, 2007 | 01:32 AM
6mustang6's Avatar
6mustang6
Default RE: Hipo?
you mean 4 main caps, or 4 bolt mains? Im sure you mean 4 main caps right? SO is it worth picking up?
PS I just realized you're way ahead of me in posts.[:@] I got to start posting more. Whenever you get that Fastback together we need to meet up somewhere's around her in Georgia.
Old Jan 13, 2007 | 01:41 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Default RE: Hipo?
yeah the mains are a little beefier (they are flush all the way across the standard 289/302 blocks only are a little beefier around the bolts)
the only small block from the 289/302 to get 4 bolt mains was the 69-70 boss 302
Old Jan 13, 2007 | 01:47 AM
eZ's Avatar
eZ
Default RE: Hipo?
i always use times like these to upgrade. if you can afford it upgrade to some drilled and slotted rotors and upgrade the calipers. you can get them powder coated for about 50$
[/align]
Old Jan 13, 2007 | 01:55 AM
6mustang6's Avatar
6mustang6
Default RE: Hipo?
i think you posted on the wrong post EZ. If you didn't... WTH Are you smoking?
Old Jan 13, 2007 | 02:19 AM
eZ's Avatar
eZ
Default RE: Hipo?
LMAO...wow too much hot chocolate....sry
[/align]
Old Jan 13, 2007 | 02:20 AM
atomsk680's Avatar
atomsk680
Default RE: Hipo?
lol funny, ive done that before eZ
GimpyHSHS
Aug 29, 2015 06:30 PM
paddy187
Aug 15, 2006 06:59 PM
hellas85stang
Archive - Trades & Freebies
Jul 24, 2006 12:52 AM
UBY289
May 24, 2006 10:28 AM
SpudRacer
Dec 19, 2005 11:33 AM
