Throttle Linkage problem
Old Jan 16, 2007 | 02:07 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default Throttle Linkage problem
The other day, someone mentioned that my throttle linkage needed a new collar, so I ordered one from Texas Mustang. Well, it came in yesterday, and when I went to put it on, I found that the original one was still good, but the hole in the throttle bar was just too big for it. It is the same size as the one I got from Texas Mustang. So, am I missing a part? Picture 1 shows the hole, pic 2 shows the collar in the hole and how much space needs to be taken up, pic 3 shows the new part, and pic 4 shows what may be a solution. The new part fits snugly inside that 1/2" od tubing which fits nicely inside the big hole, and Wallah! No slack left. I just have to cut the hose so it's only about 1/8" long. Is this a fix, or do I need to order another part?
[IMG]local://upfiles/10034/903420C04ECB444192B09D1E90A9004D.jpg[/IMG]
[IMG]local://upfiles/10034/F81A34EB3A9D4872BC2E5E7CC3A86093.jpg[/IMG]
[IMG]local://upfiles/10034/32A30A0E41EC447F89FC180440BD1339.jpg[/IMG]
[IMG]local://upfiles/10034/9731C39FD3A743B7969D40BEC518B06C.jpg[/IMG]
Old Jan 16, 2007 | 02:16 PM
atomsk680's Avatar
atomsk680
Default RE: Throttle Linkage problem
maybe some small gasket or something around the bolt, i will look on our 71 when i get home in a few hours
Old Jan 16, 2007 | 02:23 PM
Soaring's Avatar
Soaring
I ♥ Acer
I think it would be a rubber washer type thing with grooves cut on the outside edge, and it presses inside the big hole. But, I don't know because it has never been on the car since I have owned it. Would some of you pony years guys look at yours and let me know what I am missing, just in case Atom's 67 is different? BTW, I just got back from the garage after cutting the hose and sliping it in the hole with the collar inside it. It works like a champ.
Old Jan 16, 2007 | 02:28 PM
atomsk680's Avatar
atomsk680
ORIGINAL: Soaring
69 glen, i have a 69[8D] my carb isnt hooked up but the 71's 302 is hooked up, ill look at that too see when i get home, and other people look at theres
Old Jan 16, 2007 | 04:10 PM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
just go to your local ace hardware and get a nylon bushing that will fit
Old Jan 16, 2007 | 04:37 PM
gothand's Avatar
gothand
There should be a nylon bushing inside of a rubber shell which fits into the linkage. Your cut piece of hose essentially simulates the rubbershell that you appear to be missing. You could order a new one if it bothers you, but unless yours is binding, it appears that you're good to go!
Old Jan 16, 2007 | 06:03 PM
stangimgood's Avatar
stangimgood
[align=right]
[/align]
THROTTLE ROD MOUNTING KIT 1964-1969
V8
Details
Soaring............... i think the part you are missing is the third from left in the pic in the brakedown...click DETAILSto see....cjponyparts has in stock
http://www.parts123.com/parts123/yb.dll?parta~partsort
that is the same part missing on ours...don
[align=right]Part #: [/align]
HW1337
Price:[/align]
10.95
TfcCDR
Sep 14, 2015 12:08 PM
Sep 8, 2015 11:50 AM
94stangnewbe
V6 General Discussion
Sep 7, 2015 07:39 PM
zanemoseley
Sep 6, 2015 12:58 PM
5.0 kevo
Sep 3, 2015 06:24 PM
