OK, C4 Tranny Experts
Someone told me that there's a vent tube or vent cap where fluid will leak from if the tranny is overfilled. I have a leak that I can't find and thought that might be the problem.
Some C4's, especially the ones that went into Broncos, had a vent on top of the transmission. The problem with them, is that when the car or truck gets at a steep angle, the fluid leaks out. Some people have found a fitting and attached a hose to it and routed the hose above the transmission so that this doesn't happen. You may or may not have a vent on your C4, but if you do, here is what it looks like.
http://www.azbronco.org/pics/tztcb01.jpg
OK, thanks. I'll look for it up top. This leak has gotten the best of me. I can't find it, but the Ujoint at the output shaft is always covered with fluid. I pulled the drive shaft and the chamber where the yoke goes into is dry. Go figure!!!!
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
