69-70' Headlight Bezels
Old Jan 22, 2007 | 02:30 AM
dlynch's Avatar
dlynch
Default 69-70' Headlight Bezels
I posted a thread earlier about swithing 1970 head light bezels with 1969 bezels. I'm woundering if anyone out there would have a picture of the back of the 1969 bezel. Also if i could get the front fenders measurements that would be sweet.
Old Jan 22, 2007 | 04:02 AM
atomsk680's Avatar
atomsk680
Default RE: 69-70' Headlight Bezels
the 69 headlight buckets should fit fine in the 70 fenders, one of our other members has 70 fenders on his 69 coupe, your gunne need a new grille while your at it
Old Jan 22, 2007 | 01:25 PM
moparmatt89's Avatar
moparmatt89
I have 70 fenders and a 69 headlight bucket. It wont just fit, i had to cut up and modify the brackets on the inside of the actual fender where the headlight bucket sits, it was no big deal, took 15 minutes. I wish i had some pictures for you, but i was stupid and didnt take any!
Old Jan 22, 2007 | 03:55 PM
dlynch's Avatar
dlynch
thanks for the replys. im going to check around the local junk yards for some new bezels. what els would i have to replace once i switched the bezels. grill, trim? what about the head light wiring?
Old Jan 22, 2007 | 04:05 PM
atomsk680's Avatar
atomsk680
ORIGINAL: dlynch
grille, trim, the wiring yes, your going to need the 69 grille and foglights
Old Jan 22, 2007 | 08:16 PM
dlynch's Avatar
dlynch
what all on the wiring will i have to chang?
Old Jan 22, 2007 | 08:22 PM
atomsk680's Avatar
atomsk680
well the 2 main headlights are in the grille, you just have to make sure they make it to the new location in the headlight bucket, then if you already have fog lights you need to just connect the old harness to the new grille lights and if you dont you need to wire them in
Old Jan 22, 2007 | 09:12 PM
dlynch's Avatar
dlynch
sounds alot easyer then what i thought it was going to be. does the bezel have the same bolt patterns or do i need to drill new holes in the fender?
StalkerGT
Nov 28, 2015 03:09 PM
Seanam
Oct 4, 2015 10:15 AM
Drastang
Sep 29, 2015 03:31 PM
Mobiusone stang
Sep 7, 2015 08:46 PM
amandahchase
Sep 3, 2015 10:09 AM
