67-68 cowl replacement kit
Old Jan 22, 2007 | 12:20 PM
jcarden's Avatar
jcarden
Default 67-68 cowl replacement kit
I see an entire replacement kit for the top and bottom sections of the 67-68 cowl. My question is this. How does the cowl on a 67-68 differ from a 66. Can this kit be adapted or does the design differ too much?
My 66 needs the typical bottom sections replaced from what I can tell with it assembled. There is also some rust holes on the top half along the sides just above the spot welds. Can I cut the sheet metal from this kit and use it verses finding a donor 66 to get the sheet metal in the shape I need to fix the upper section?
Jason
Old Jan 22, 2007 | 12:25 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Default RE: 67-68 cowl replacement kit
the upper is different but the lower can be used i think only one or two holes are different according to an article i read
for the hole on the upper part just weld in some new patches while u have it apart
Old Jan 22, 2007 | 01:00 PM
grruminator78's Avatar
grruminator78
are the dimensions any different??, who cares, even if they are some carefull grinding, and welding and you have a brand new cowl!
Old Jan 22, 2007 | 01:14 PM
Grimm's Avatar
Grimm
I am currently in the middle of a cowl project and though I'm not sure of the measurements the panel looks right except the opening on the base, and the indentation between the wiper arm openings.
Granatelli Sales
Jan 20, 2020 12:34 AM
Nick Oliver
Oct 17, 2018 04:22 AM
cbird1177711
Sep 3, 2015 08:43 PM
5.0 kevo
Sep 3, 2015 06:24 PM
Sep 1, 2015 08:16 PM
