Comp Cam questions
Hey guys,
Can't figure this one out. I am looking at buying the Comp Cam XE262H for my 289. If you look at the Cam on Jegs where I'd buy it, the specs are much different than on Comp's page. Which is correct?
See the Xtreme Energy 262H SBF CAM specs on this page, its the third one down:
http://www.jegs.com/webapp/wcs/store...46624_-1_10707
Nowclick on the specs on this page,same model:
http://www.compperformancegroupstore...ry_Code=31-CAM
Why doesComp have the lift at .493 and .5 exhaust while Jegs has it much lower. I also noticed that Comps page says the next more aggressive Cam ,the XE268H, needs minimum 2200 stall, while the same model Cam on Jegs says its thelargest Cam you can get with stock converter. \
Basically I want the largests CompXE Cam I can get with the stock converter to match my AFR heads....
any ideas here? Isthe difference the grinds?
Luke9222
Oct 22, 2015 11:55 PM
uberstang1
Sep 20, 2015 06:42 PM
