Headhight switch removal
Old Jan 25, 2007 | 10:39 PM
my67pony's Avatar
my67pony
Default Headhight switch removal
How do you remove the headlight switch from '67. Looking at the book it looks like the **** and shaftshould unscrew then pull out .But how much torque? I'm afraid I might twist it off. I'm removing the **** and bezel to paint the instrument panel area and do notnecessarily want to replace it. Might just have to tape it off.
Old Jan 26, 2007 | 12:05 AM
Cogtx's Avatar
Cogtx
Default RE: Headhight switch removal
Gary...there is a button on the side of the switch which you have to push and hold to remove the **** and shaft.The **** and shaft do not screw off. Need some small hands/fingers to get to it inside the dash area. I don't have pic of the switch but you might find one thru google search...
more instructions..
First, you will have to remove the pull-rod. This is done by pulling it out as far as it will go (the 'on' position) and then depressing the release button while continuing to pull outwards. This button is located on the switch body on the opposite side from the connectors (usually to the right side of the car). Once that is removed, you merely need to unscrew the bezel using a large flat-head screwdriver and then remove the switch.
Old Jan 26, 2007 | 01:44 AM
my67pony's Avatar
my67pony
God I love this forum! ya all so helpfull.
Old Jan 26, 2007 | 11:11 AM
grruminator78's Avatar
grruminator78
just a tip, put a couple of shop towels (blue paper kind) on the end of the screwdriver when unscrewing. It'll save you from scratching up the bezel, also you may want to remove the instrument cluster to give you a straight shot to the thing with your hands and also gives you some working room, plus you can see what you are doing
Old Jan 26, 2007 | 12:08 PM
kalli's Avatar
kalli
i'm new to this forum but I've seen the same question for the 5th time by now I think. maybe something for the FAQ .... ;-)
Kalli
Old Jan 26, 2007 | 02:08 PM
grruminator78
it's not that hard really, when I removed it, I took off my shifter so I could lay across the floor. Then when I got the part I was also doing some work to the instrument pannel and said to myslef, "self, look at all the room you have in there and you're not on your stinking back!!" Just little tips.
Oh yeah and hold the bugger as you unscrew it or you'll torque the entire thing and could break something.
jwog666
Dec 27, 2021 08:09 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
PaulH2
20
Jan 31, 2016 09:48 AM
Dathan
Oct 5, 2015 05:52 AM
guitarman376
Sep 30, 2015 05:54 PM
