help getting a 351
Old Jan 29, 2007 | 06:37 AM
ADRIAN1's Avatar
ADRIAN1
Default RE: help getting a 351
you got a good point!..
Old Jan 29, 2007 | 02:10 PM
ADRIAN1's Avatar
ADRIAN1
whats the diffrence betwwen?..what does 4v or 2 v mean? ...which is better?
Old Jan 29, 2007 | 02:32 PM
Shifty101Easy's Avatar
Shifty101Easy
generally its refering to 4v (4 venturi) is a four barrel carberator....2 is ....well...2 barrel.
Old Jan 29, 2007 | 02:36 PM
ADRIAN1's Avatar
ADRIAN1
SO THIS WOULDNT REALLY MATTER IF IM GOIN TO START BUILDING FROM A BARE BLOCK RIGHT, BECAUSE I CAN JUST TURN A 2V TO A 4V RIGHT?
Old Jan 29, 2007 | 02:52 PM
Grimm's Avatar
Grimm
Yes. Just get a 4V intake.
Old Jan 29, 2007 | 05:00 PM
THUMPIN455's Avatar
THUMPIN455
Pretty much.. you arent planning on a 600hp engine are ya? Well either block will work just fine. If you are going to build a 600+ engine from a 351W, then an aftermarket block would be a good idea, but for a driver, ANY of them will do as long as its in good shape. You arent going to drop the crank out the pan with 350hp...
Old Jan 29, 2007 | 10:48 PM
my77stang's Avatar
my77stang
if you grab that marine motor it will have a larger cam from the factory (not by much) but MAKE SURE ITS NOT RUSTED OUT. alot of marine motors suffer from massive internal rot in the water jackets.
Old Jan 29, 2007 | 10:57 PM
mustanglover66's Avatar
mustanglover66
If you can't take a head off to check the water jackets I would stay away from the marine block because they usally have a lot of rot on the inside. And if you wait for A roller block you will most likely pay out the nose for it because they are rare and highly desired.
Old Jan 29, 2007 | 11:34 PM
my77stang's Avatar
my77stang
yeah i seem to recall that the 351's were flat tapper longer into the 80's than the 302's - but i could be mistaken. anyways all you need to use roller cams in a early block is the retrofit lifters. they are a little more than regular rollers but you'll save on the block and find one quicker..... it all works out in the end
Old Jan 30, 2007 | 03:11 PM
ADRIAN1's Avatar
ADRIAN1
is a 351C the same as a 351W with diffrent heads? can the C be just as fast as the W if i put equal amount of money on them?
