help getting a 351
i found a 351W from a 1977 wagon. the guy is asking $150 o.b.o!! he said that it was running when taken out. is this a good deal? what year 351 should i get or from what car? is a windsor better or cleavland?...
depends on what u want, do u want to mod the hell out of it, then get a newer one like 84 and up i think they are all roller motors, but if u want stock then get a 69-70 they make good power. its most likely a windsor motor, but check and c, also the cleveland is better b/c the heads and intake. but the windsor there is more parts for it so its ur choice.
ORIGINAL: ADRIAN1
what year 351 should i get or would work best?...
Why does this '73, 351W have a wierd tube with some red nozzle going to the carb?,,along with the other stuff? ...can i use this engine for my '65?
[IMG]local://upfiles/27709/4C0C120130AF4787AC69D473E8A07CB7.jpg[/IMG]
ORIGINAL: ADRIAN1
If you can get a good running core for $150 just go buy it. Pull the pan and check the bearings and stuff before you plunk down your cash. If it doesnt have anything spun or broken, then it should be a decent core, provided it isnt cracked from cold.
Doesnt matter what year, all the parts interchange for the most part. Flat tappet cams still work okay, no need to hold out for a roller block. Ws are good engines and alot easier to find than Clevelands. Cs had better heads, but there are more Ws out there and the aftermarket has plenty of heads.
Just go get it and make sure it isnt cracked.
ORIGINAL: THUMPIN455
MARINE ENGINE...
ORIGINAL: ADRIAN1
theres another '77, 351W goin for $150 o.b.o..
..i wanted a '71-'74 block because its a little more beefier...but what would you guys do? these are the 2 options i have right now...what should you guys do?
the cheaper one as long as the block is in good shape....if your going to mod it id assume your going to be getting a bunch of new stuff.....so what your really looking for is a base to work off of....why pay double for the same thing? and i sorta dont think from what im reading that your going to build something so gnarly its going to crack the block or something....so the "beefier" one isnt really necessary i'd say.....
, so i guess im gonna have to go with the '84 and up models right?
