help getting a 351
no, a C is a completely different engine family/design
yes a C can actually make MORE power than a W but it'll cost you more money, and will add alot more weight up front. unless your trying to make 1000 HP i'd seriously stick with a W motor. parts are cheaper, easier to find, and they are very reliable and dependable motors.
i remember seeing someone ( i think "soaring" ) that posted a little list of the diffrent years and a little description. for example:
1969-1970: high nickle, and thick webbing.
1971-1974: ....
1975-...
pleasde post again!
thanks!!!
1971-1974: ....
1975-...
pleasde post again!
thanks!!!
ORIGINAL: ADRIAN1
1971-1974: ....
1975-...
pleasde post again!
thanks!!!
1971-1974: ....
1975-...
pleasde post again!
thanks!!!
Anyway.. if you want a 351, the W will fit better than the C in your car. You dont need to worry about how strong the block is unless you are going to make alot of power with high compression, high rpm, or high boost. You will lose a rod or break a piston before you break a stock block with a budget type build..
The 65-66 Stangs are like the 70-74 Mavericks under the hood. We were going to put a 351C 4V in a 71 Maverick for my dads toy.. I can assure you it is not a simple bolt it in swap. Also have a friend who is running a Farimont with a mid 70s 351W, and some ported 69W heads, he was running 12.80s and had less than $6000 in the entire car.. Just get the W and build it.
ORIGINAL: ZZmustang
Doesn't the 351 marine engine run backwards? Seems I heard that somewhere.
Just having one engine in a boat doesnt require reverse rotation.. I have learned all this since dating the present GF, her dad is a boat guy who does deep sea fishing charters on Lake Superior, and he sells and repairs boats. There are more boats in my yard than cars..
ok, well i just made a phone call toi a guy whos selling a 69 351w block for $100 and he said hes goin to inspect it to make sure its not cracked; and if its not im going to pick it up on Sat.!!
make sure he's got the main caps LOL
im pretty sure the reverse rotation marine motors have different pistons (or they are turned around backwards..... i remember something about that.
ORIGINAL: my77stang
