autolite carb CFM question
Old Jan 29, 2007 | 10:49 PM
bradleyb's Avatar
bradleyb
Default autolite carb CFM question
when I bought my 66, the guy gave me a Autolite 4 barrel carb, the id plate says "C7DF D" and underneath that in smaller letters is "B7 AA". Can anyone tell me the CFM of this carburator and how much would be a reasonable price for shop to do a re-build, thanks???? I haven't donea re-build on a carb in a couple of decades, how hard is this????? Should I considerdoing this myself, I amsomewhat competent to domost things but have never tackled this- I used to do this on my dirt bikes back in the 70's when I was a kid, but that is a long time ago
Old Jan 29, 2007 | 11:24 PM
bradleyb's Avatar
bradleyb
Default RE: autolite carb CFM question
the guy told me that the carb was from a 67 deluxe (would that be a 289 hipo engine????)
Old Jan 29, 2007 | 11:31 PM
coda618's Avatar
coda618
On the forwrd left hand side of the fuel bowl ther will be a number in a circle, either 1.08 or 1.12. I don't remember the exact cfm, but the 1.08 I believ is something like 480 and the 1.12 is about 600cfm. I am sure someone will provide you with the exact specs.
Oh, and rebuild it yourself with a quality kit. It is not as hard as it may seem at first. It is not difficult, just stay organized.
Good luck.
Old Jan 29, 2007 | 11:44 PM
bradleyb's Avatar
bradleyb
thanks Coda, I may have to give it a shot - I think the kits are around $35 bucks on ebay (autica). anyone have tips on buying the rebuild kits?
Old Jan 30, 2007 | 06:52 AM
j code kid's Avatar
j code kid
wats the best way to / and fluid clean it out ,??,also i heard the air horns fine holes block up and give a alot of problems ,,start up .. idling etc.....i have a orig. 4 barrel on me j code and it needs an overhaul bad thanx 4 any clues .................................................. ..................
Old Jan 30, 2007 | 07:08 AM
Soaring's Avatar
Soaring
I ♥ Acer
That's a good carb. Certainly overhaul it yourself. It's probably one of the easiest 4 barrel carbs to tune.
Old Jan 30, 2007 | 10:40 AM
coda618's Avatar
coda618
Get a quality kit i.e. motorcraft. They are available on ebay. Or call Pony Carbs and they will give you a specific kit.Check your part numbers to make sure you get the correct kit. May also wnt to consider replacing floats and choke stat.
When I did my carb, I dissassembled and used gunk carb kleen and a soft (brass) brush on the body. I then did a final rinse and blowout with brake kleen. I inserted the thin tube into the passages and blew the passages kleen. Then compressed air. I also polished the body with a dremel and wire brush attachment.
Also, if you do not have a ford shop manual, get one. They have a good step by step rebuild process, as well as complete tuning instrucions. The carb kits come with instructions, but I found that they compliment each other and used both to refer to in my rebuild. Also, tke some pictures of the choke linkage and other parts as you dissasemble for reference when re-assenmbling.
Good luck.
Old Jan 30, 2007 | 10:42 AM
j code kid's Avatar
j code kid
the previous owner said it had been recod and the choke area and housing had been cut off very neatly ,it also seems to flood
Old Jan 30, 2007 | 10:45 AM
j code kid's Avatar
j code kid
looks pretty easy ,,that 6mm or so little metal bevelled flat top thingo .....wheres that go ??????????????
Old Jan 30, 2007 | 07:06 PM
bradleyb's Avatar
bradleyb
thanks guys, I think I am going to give this a shot..... first stop the soak tank
