Frame rust
Old Jan 31, 2007 | 01:08 AM
StangDB's Avatar
StangDB
Default Frame rust
On my 67 the frame under the front bumper mounts has rusted out, how would i fix or replace that? would a notch and patch method work?
Old Jan 31, 2007 | 01:25 AM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Default RE: Frame rust
pics
Old Jan 31, 2007 | 11:22 AM
coda618's Avatar
coda618
Almost all the parts vendors carry patch peices. You can get an outer frame rail patch and an inner seperatley. Look at the websites to determine which you need. Generally, you can cut the spot welds and cut out the rotted peice and weld in a patch. This is a common repair on mustangs. Also, check the FAQ's, there are some articles on rust repair.
Good luck.
Old Jan 31, 2007 | 05:52 PM
Pattie's Avatar
Pattie
that section of frame rail is normally inexpensive. And not to hard to replace. When you replace just make sure you get all the rusted section gone.
b8checker
Oct 8, 2015 12:55 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
b8checker
Sep 30, 2015 07:11 AM
mrappe
Sep 26, 2015 10:16 AM
tmdm
Sep 18, 2015 03:10 PM
