Gears
Old Feb 1, 2007 | 08:33 PM
fast65's Avatar
fast65
Default Gears
I have a 65' GT and all I know about the gears is that they're low. I would like to get better gears for it; it already has good acceleration but I was wondering what kind of gears would give me some good acceleration but also a higher top speed. I don't care about gas mileage because I drive with the pedal to the floor everywhere I go anyway. So what would you guys recommend?
Old Feb 1, 2007 | 08:37 PM
6t9 stang's Avatar
6t9 stang
Default RE: Gears
3.55 will get what you are after, but they will also be ok for highway driveability
Old Feb 1, 2007 | 08:39 PM
fast65's Avatar
fast65
Default RE: Gears
Thanks. I'll check those out.
Old Feb 1, 2007 | 09:07 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Gears
Yeah, 355 to 375. If you go to 410's you will be revving very high at 70 MPH, but will have a screamer off the line.
Old Feb 1, 2007 | 09:18 PM
69FECoupe's Avatar
69FECoupe
Default RE: Gears
Before you decide on a new ratio, you need to know what you have now so you have a starting point. If you want a higher top speed, you'll need to go with a numerically lower ratio. If you want a better hole shot, you'll need to go with a numerically higher ratio.
Old Feb 2, 2007 | 01:18 AM
6mustang6's Avatar
6mustang6
Default RE: Gears
Go with the 3.25-3.55, Also, You have a HIGH gear. The lower the number, the higher the gear. The higher the number like 4.11 for example is a low gear. You have a high gear.
Old Feb 2, 2007 | 01:07 PM
fast65's Avatar
fast65
Default RE: Gears
Okay, thanks for the help you guys.
Thunderball
15
Nov 22, 2015 11:49 PM
Bokeo
Oct 10, 2015 08:28 PM
KingRando
Oct 2, 2015 08:06 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
