question about starting off
Old Feb 8, 2007 | 04:39 AM
70coupe's Avatar
70coupe
Default question about starting off
when im at a stop light or anything i have to hit the gas pretty hard to get going is this normal or is there something i can do to improve this?
Old Feb 8, 2007 | 05:15 AM
longlive289s's Avatar
longlive289s
Default RE: question about starting off
70 coupe eh? whats the engine?....nm im an idiot
could b many problems. sounds more like fuel but need more specs. check fuel filters, air filters, spark plugs, cap, points (if u have em), etc
Old Feb 8, 2007 | 05:34 AM
ford65stang's Avatar
ford65stang
could it be throltte linkage could be getting stuck ? maybe try wd 40 on the connections.....i would try that.....check your tanny fulid....could be low, causing you to increase rpms to move...... could be the rear end fulid is all gunked up....
when you're you driving at 20 mph or so.....and you give it gas...does it accelerate, or do you have to have the gas pedal all the way down the whole time.
Did this problem just start ? did you buy it alreadly like this ? or what.......
Old Feb 8, 2007 | 06:35 AM
longlive289s
doubt it would be linkage getting stuck. if it was stuck idle ud feel a pop when u slammed the gas and otherwise ud DEFINITELY know it was stuck cuz ud take your foot off and the car would continue going.
tranny....maybe, very much doubt it. if u hear the car accelerating and not going ne where then the tranny or the torque converter is the colprit.
again....check electrical and fuel flows
Old Feb 8, 2007 | 02:33 PM
70coupe's Avatar
70coupe
well i just had the tranny rebuilt about a month ago so i dont thing it should be that unless they did something wrong...the bad thing is that i have nothing to compare it with cause when i bouht it the tranny was already shot.
Old Feb 8, 2007 | 09:18 PM
kalli's Avatar
kalli
i had the same probleen when I got my car. It was "wrong air" getting into the carb (too lean).
Basically a hose connected to the carb ending in nowhere wasn't blocked.
On the same the vacuum hose going to the distributor. If the vacuum advcane doesn't work anymore (isn't sealed anymore) it'll pull air there.
All in all had same probelm when running far too lean
Kalli
Old Feb 8, 2007 | 11:05 PM
70coupe's Avatar
70coupe
sweet thanks for the info
GimpyHSHS
Aug 29, 2015 06:30 PM
toastintx64
Aug 29, 2015 05:12 PM
Calizic
Aug 28, 2015 01:46 PM
stormesixx
Aug 25, 2015 09:11 AM
