clevor thinking
Old Feb 11, 2007 | 11:59 PM
ih8chevy's Avatar
ih8chevy
Default clevor thinking
does anyone kno specifically how hard it is to make cleve heads fit the 351 w block.
Old Feb 12, 2007 | 12:18 AM
my77stang's Avatar
my77stang
Default RE: clevor thinking
theres a few write-ups on it.... not too hard, but your machine shop needs to know wtf they are doing. and you'll need a proper intake
Old Feb 12, 2007 | 12:25 AM
ih8chevy's Avatar
ih8chevy
yea i thought the intake from a normal 351 cleve would do the trick
Old Feb 12, 2007 | 01:08 AM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
no you need a 351W intake cause what you are doing is plugging the water jacket that goes back into the block and then openin it up to flow into the intake
Old Feb 12, 2007 | 01:16 AM
Brandontyler65
I ♥ Acer
umm the back of my ford racing catalogues has a guide on how to do it with measurements
Old Feb 12, 2007 | 01:17 AM
ih8chevy's Avatar
ih8chevy
what catalouge is that what issue?
Old Feb 12, 2007 | 01:27 AM
Bentworker's Avatar
Bentworker
A clevor would be very cool. CHI are the kings of that setup, from what I understand you run a Cleveland intake, then you machine the cleveland heads for an external crossover.
goddam forum won't take the link.. check out chiheads dot com
http://www.chiheads.com/
http://www.chiheads.com/index.php
Old Feb 12, 2007 | 01:35 AM
Brandontyler65
I ♥ Acer
looks like a windsoe intake on this clevor
Old Feb 12, 2007 | 01:39 AM
Bentworker's Avatar
Bentworker
Pulled this from CHI's website. They charge $150 for the crossover
"CHI's water-crossover / bypass housing is the perfect accessory for our new range of inlet manifolds, allowing you to easily convert your 8.2" & 9.5" deck Windsor engines into an all conquering BOSS power plant. Designed to replace the integral water passage and thermostat housing used on Windsor intake manifolds, our water crossover redirects the water out of the front of your CHI - Cleveland - Yates Cylinder heads, and conveniently relocates the thermostat housing horizontally above the original Windsor position.
Our kit comes complete with all the necessary hardware (fittings, hose, hose clamps and mounting studs) to make the installation as simple as possible. The housings are heat treated for longevity, providing our customers with many years of trouble free service.
Installation is accomplished by removing the 2 top bolts of your Windsor timing cover and replacing them with the provided studs, on which the thermostat housing will be located. Any customer's pre ordering cylinder heads and manifolds to suit Windsor blocks, will have their cylinder heads drilled and tapped for our water crossover - bypass housing, from CHI at no extra cost
Old Feb 12, 2007 | 01:43 AM
ih8chevy's Avatar
ih8chevy
well i think i might stay just with a cleve, cause all the parts it sounds like it will cost more and net similar power.
anyone else
