lowering ride height
Old Feb 26, 2007 | 05:03 AM
andrewmp6's Avatar
andrewmp6
Default RE: lowering ride height
damn we need some of those big speed bumps over here lol
Old Feb 26, 2007 | 05:13 AM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
thats exactly what i am gunna do i am gunna do the shelby mod with a 620 spring but i am worried about the ride hight so there are two things i am considering either the 1" poly insulator or the 3/4" metal one made by global west but i dunno what one to use
Old Feb 26, 2007 | 07:36 AM
latamud's Avatar
latamud
ORIGINAL: baddog671
I am also considering doing the Shelby mod and alittle confused. So if you have a 620 spring that is 1" dropped, and you lower the UCA 1", would it still be ok? I thought you only needed to compress the springs about 2" to install them and that would make fitment loose...
The 1" drop coils will drop the car 1" from factory stock. Now, your factory coils probably have sagged over the past 40 years so are already lower than stock. You might install the 1" lowered 620's to find it raises the car? maybe. If they are too tall and you cut them, then it makes a stiffer spring rate. I cut 1.5 coils out of my 620's and now they feel like 720s. Loered my car to where I want it and stiffened up the front to handle the extra weight of my engine.
Old Feb 26, 2007 | 10:58 AM
baddog671's Avatar
baddog671
ORIGINAL: latamud
ORIGINAL: baddog671
I was just worried if you can do the shelby drop paired with dropped springs. I didnt know if that would too much of a distance and the spring not seat properly, i dont know how to explain it better..
Old Feb 26, 2007 | 06:56 PM
latamud's Avatar
latamud
yes, you can do the shelby drop and use lowering springs. The shelby drop is a suspension upgrade, but just happens to give about 1/2" lowering of the ride height. Do a search on the shelby drop to see what it can do for you. Research, don't just do it on blind faith. Know your car.
lincolnshibuya
Jul 5, 2020 03:05 AM
UrS4
Oct 3, 2015 06:23 AM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
1Bad71
Sep 30, 2015 07:37 PM
Sep 27, 2015 03:16 PM
