Will 17's fit
Old Feb 28, 2007 | 05:44 PM
65mojoe's Avatar
65mojoe
Default RE: Will 17's fit
coys are a nice rim. The spoke design is basically the torque thrust style, but then the dish is smooth as apposed to the TT's stepped design. They are nice rims, although I would rethink the chrome.....go with polished (looks more natural).
Old Feb 28, 2007 | 06:09 PM
66JameStang's Avatar
66JameStang
225-45-17
Old Feb 28, 2007 | 06:35 PM
74cruzah's Avatar
74cruzah
But the chrome is so shiny. Can't resist the shine. Forgot to mention that I am doing 235/45 with 7" wide wheels on the front and 255/45 with 8" wheels on the rear. Hopefully they fit.
Old Feb 28, 2007 | 06:54 PM
66JameStang
forgot to mention the only problem with the profiles were in the front I went with larger ones in the rear.
Old Feb 28, 2007 | 08:25 PM
65mojoe's Avatar
65mojoe
ORIGINAL: 74cruzah
Have you seen the chrome C-5's in person? IMO, most all chrome plated rims look fake. You can buff a polished rim to just as shiny a finish, but it still looks so much more natural than chrome. Plus you dont have to worry about flaking.
Your tire setup should look pretty sweet. 255's on an 8" rim will start to have a little bit of a bulging sidewall.
Old Feb 28, 2007 | 09:26 PM
latamud's Avatar
latamud
http://www.dodgestang.com/Tire%20Fit...ide%2067-8.pdf
Old Feb 28, 2007 | 10:38 PM
edgars23's Avatar
edgars23
4 lug? I would consider stepping up to the 5 lug conversion if you can first, then get the rims and tires. If you ever decide to go with disc brakes up front, you will need to chage to the 5 lug bolt pattern (unless someone makes a 4 lug disc setup that I am not aware of.
-Edgar
Old Mar 1, 2007 | 01:45 AM
hardroxs19's Avatar
hardroxs19
about how much would the parts cost to convert it to a 5lug set up?
what would i need?
Old Mar 1, 2007 | 05:45 AM
andrewmp6's Avatar
andrewmp6
cheapest way to do the front is a granada swap rear youll have to buy a 8 inch or 9 inch rear end
Old Mar 1, 2007 | 05:40 PM
66JameStang
You can also go with V-8 mustang spindles instead of the granada if you would like I don't see any for 67 specifically but I can't recall if there is a huge different between the 66 and 67 spindles, If you are gonna use the granadas wouldn't they be different as well for 67.
Front
Disc Kit
http://cgi.ebay.com/ebaymotors/65-72...ayphotohosting
http://cgi.ebay.com/ebaymotors/1964-...88541575QQrdZ1
Rear
http://www.currieenterprises.com/ces...amp;p=964.9500
jwog666
Dec 27, 2021 08:09 PM
mustangheaven
Jan 3, 2016 11:20 AM
BeatnikFink
Oct 1, 2015 08:00 PM
fastbackford351
Oct 1, 2015 12:24 PM
mdg
Oct 1, 2015 07:04 AM
