wheels
Old Nov 2, 2004 | 10:44 PM
L8ER's Avatar
L8ER
Default wheels
OK, I have another one, what is the largest rim I can fit (to the edge of the wheel wells front and rear but not beyond? I need to know what backspacing to order as well. I've been thinking about a set of Cragar SS's just to be nostalgic
Old Nov 3, 2004 | 07:21 PM
69mach1377's Avatar
69mach1377
Default RE: wheels
Not enough info here to help you...
Old Nov 4, 2004 | 04:25 AM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: wheels
What year and model of Mustang do you have?
Old Nov 4, 2004 | 08:42 AM
L8ER's Avatar
L8ER
Default RE: wheels
1968 coupe, an original 289 car.
Old Nov 4, 2004 | 12:07 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: wheels
Front - 18X8 4.5 BS Tires - 245X40X18
Rear - 18X9.5 6.0 BS Tires - 265X35X18
Old Nov 4, 2004 | 12:20 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: wheels
Front - 18X8 4.5BS Tires - 245X40X18
Rear - 18X9.5 6.0BS Tires - 265X35X18
Old Nov 6, 2004 | 12:40 AM
L8ER's Avatar
L8ER
Default RE: wheels
That's a little larger than what I had in mind. I was thinking more in terms of a 15 inch rim.
Old Nov 6, 2004 | 09:56 AM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: wheels
ORIGINAL: L8ER
Then you should have said so. You asked for the largest, and that's what I gave you. There are a ton of 15 inchers out there, just do a google search.
Old Nov 6, 2004 | 10:07 AM
L8ER's Avatar
L8ER
Default RE: wheels
My apologies for not being clearer. What I need to know is what is the WIDEST 15 inch rim that will fit, front and rear, without going past the wheel wells. I will also need, if anyone knows, the backspacing so the tires wont rub.
Old Nov 6, 2004 | 10:41 AM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: wheels
ORIGINAL: L8ER
Just get rid of the 18 and add a 15 to the info already given. BS is still the same.
jwog666
Dec 27, 2021 08:09 PM
UrS4
Oct 3, 2015 06:23 AM
mungodrums
Sep 28, 2015 10:54 PM
folivier
Sep 26, 2015 02:28 PM
lincolnshibuya
Sep 24, 2015 10:46 PM
