Carb Spacer
Old Mar 8, 2007 | 03:46 PM
palerider's Avatar
palerider
Default Carb Spacer
I need to put carb spacer on my 289 performer edelbrock, 600 holley, 302 motor to get another inch for ram set up I'm doing to work. Was looking at 4 hole (heard a little better low end). Seen a couple options. A Mr gasket for $25 dollars and the attach for $90. The $90 dollar one has some twist in the bores they claim to be more effiecient. Just wonder what folks think - marketing hype?
http://store.summitracing.com/partde...p;autoview=sku
Old Mar 8, 2007 | 04:21 PM
grruminator78's Avatar
grruminator78
Default RE: Carb Spacer
just one of those Phenolic spacers, you can get them for under 50
Old Mar 8, 2007 | 04:41 PM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
don't wase your money on the swirly one just get a straight one
Old Mar 8, 2007 | 05:06 PM
boeing747arowair's Avatar
boeing747arowair
is it possible to make one. well not possible lol but would it work. i have a mill but i want to make sure if i make it to the same specs will it perform the same?
Old Mar 8, 2007 | 05:26 PM
NorCalTroy's Avatar
NorCalTroy
Check with Soaring... he'll make one out of plywood for ya!
https://mustangforums.com/m_704093/tm.htm
https://mustangforums.com/m_707328/tm.htm
https://mustangforums.com/m_1363552/tm.htm
https://mustangforums.com/m_684540/tm.htm
Non wood spacer info-
https://mustangforums.com/m_2107502/tm.htm
[edit to add links]
Old Mar 8, 2007 | 05:28 PM
boeing747arowair
holy cr*p lol plywood? wow hes hardcore!!!!!!!!!! I just want to make sure its gonna work and not waste my time, aluminum, and sweat. ( yea it isnt a CNC)
Old Mar 8, 2007 | 06:55 PM
Soaring's Avatar
Soaring
I ♥ Acer
Yep, Plywood. It works great, trust me. It's not as pretty as the phenolic spacers, but it works just like them.
Old Mar 8, 2007 | 07:03 PM
my77stang's Avatar
my77stang
i can see the wood getting saturated and then one backfire and boom your carb comes flying up thru the hood
Old Mar 8, 2007 | 07:06 PM
boeing747arowair
no no lol soaring knows all about engine fires. he is a pro when it comes to pyrotechnics up front
Old Mar 8, 2007 | 07:25 PM
gothand's Avatar
gothand
ORIGINAL: palerider
I bought a 1" spacer, mounted it and started the engine, but had to pull it off because it wouldn't clear my hood with the Edelbrock RPM Air-Gap manifold (I never had a problem with a 1" spacer and an Edelbrock Performer manifold. It is the 4-hole Mr. Gasket spacer BTW. You, or anybody elsewithin the continental U.S.can have it for $15 shipped.
BTW, don't laugh at Soaring's plywood idea. You can buy wood spacers. Oh yeah, save your time CNC'ing a custom aluminum spacer, it'll pass the heat right on through to the carb.
bradleyb
Nov 27, 2015 07:50 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
Sminemann
Sep 17, 2015 09:24 AM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
jaiidutch
Sep 14, 2015 10:29 AM
