windshield and back light replacement help
Old Mar 10, 2007 | 04:12 PM
valley firearms's Avatar
valley firearms
Default windshield and back light replacement help
Hey guys. I did my best to search the FAQ before asking this question. I think I understand but I want to double check and maybe get a few more tips. When using the rope trick, do you put the glass in the rubber then lay the glass up against the car with the rope in the ouside rubber channel? Do I seal the rubber after it is installed? I had a bunch of sticky sealant around the window opening when the winshield was removed. It was tar like and very sticky. What are the best sealants and applications? I have to buy new window trim now. I found that one of my side trim pieces is dented beyond repair. Plus I don't want to put a crappy piece of trim on the new paint job. I also have a new bag of clips for the trim. Thanks in advance!
[align=left] [/align]
Old Mar 10, 2007 | 04:43 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: windshield and back light replacement help
This article is about a Chrysler Imperial windshield replacement using the rope trick, etc. but will be the same as your Mustang because they both use a rubber seal.
http://www.imperialclub.com/Repair/Body/windshield.htm
Old Mar 10, 2007 | 05:41 PM
Smothers's Avatar
Smothers
You have the right idea. The rope ends should be in the bottom middle as I recall. Doyourself a favor and get some spray sylicone, it will help the gasket slide over the pinchweld and is extremely helpful for the corners, as they are easy to tear if not careful. Use it in generous amounts spraying it on outside edge of the gasket (or the part of the gasket that you will see on the inside after its installed). Try to keep it out of the inside of the gasket.
That sticky stuff is what we use to call dum-dum, and its probably original (if its greyish in color). We used urethane windshield sealant. Its tricky to get them sealed good and not make a mess, so be carefull. I have found the best clean up method for urethane is using citrus based cleaners. I have a tub of despensible citrus towls. They dont hurt the paint. I don't remember the name and im too lazy to run out to the garage at the moment.
Anyway, after you have the rope in, take the urethane in a caulking gun and put a bead just above the rope on the inner lip of the gasket (the part that will lay against the outside edge of the pinchweld). Trick is settingthe windshieldinto the hole in the right position the first time. You will want at least one other person holding the glass in position from the outside; two is better. Their job is to keep constant pressure against the glass while you pull the rope.Start with the left bottom corner, then the right. Then the top left corner, then the right. Should end somewhere on top. Might need to slap the outside of the glass to get it to fall into place. Not hard like you might want to bi*** slap your boss, but nice and soft like its back sideof your lady friend. More often then not, some "slapping" is required to get the windshield seated correctly.
Once you get it in, spray the excessive urethane sealer (yes there will be some) with water to neutralize its stickiness making it easier to remove.
I suggest the warmest envirnment you can manage to do the job as the gasket will be more friendly if warm. -Good luck
Old Mar 10, 2007 | 06:04 PM
Soaring's Avatar
Soaring
I ♥ Acer
Good info Smothers. Softly slapping your woman's behind huh? Now that you have your windshield in Valley, what's this about a back light? Tail light, or back-up light?
Old Mar 10, 2007 | 06:18 PM
valley firearms
Thanks guys. Great info Smothers. I will probably do the glass tomorrow because my car is still on Elmendorf AFB. I've been taking advantage of the shop there. I will have to order my reverse lights and chrome reverse light bezels as my old ones look bad.
Can I get the urethane caulking at the parts store? Does Home Depot carry it?
Old Mar 10, 2007 | 06:48 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: valley firearms
[align=left][/align]
Back in 1967, I was stationed at Ft. Richardson, and they had a fairly good auto hobby shop, but they were full one day that I wanted to put a transmission in my '54 chevy, so I took it to Elmendorf hobby shop. Been there, done that. Went to Klootch (4th street)avenue later that night and had a few brewskies.
Old Mar 10, 2007 | 08:47 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
you dont want urethane u want 3m bedding and glazing compound and the best thing for cleaning up urethane, the bedding and glazing etc is wax and grease remover and it will ntohurt the paint at all http://www.autobodytoolmart.com/p-10...ack-08509.aspx
Old Mar 11, 2007 | 04:55 AM
valley firearms
Damn rmodel, where in the hell do you learn all this stuff. There must be a wealth of knowledge in the noggin of yours.
Old Mar 11, 2007 | 05:34 AM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
he has no life lol j/k
Old Mar 11, 2007 | 08:22 AM
Soaring's Avatar
Soaring
I ♥ Acer
Doncha' know that Jawja boys are smart?
djbigskrilla
Sep 20, 2022 01:04 AM
Diode Dynamics
28
May 26, 2022 12:02 PM
bond007
Aug 26, 2015 11:36 PM
mweiland
Aug 16, 2015 10:59 AM
mweiland
Aug 13, 2015 05:11 PM
