Tune up
Old Mar 12, 2007 | 01:52 AM
  #21
my77stang's Avatar
my77stang
Default RE: Tune up
word of wisdom on autozone wires though..... dont get the "premium" wires..... they are junk, i watched the spark arc thru the boot over to my header tube. grab a bosch set from autozone - they are good wires. even better would be a set of accel 8.8's, MSD's, Taylors, Moroso, or Ford Racing wires. also make sure the distributor cap has brass pieces not aluminum, the rotor too. i noticed certain applications even the "premium" cap/rotor set would still be aluminum but then going to another auto parts store their premium would be brass. that all seems to depend on the application though, sometimes autozone has the right one, sometimes advance does, etc, etc
Old Mar 12, 2007 | 03:50 PM
  #22
Lumbergh's Avatar
Lumbergh
Default RE: Tune up
Sorry Soaring, you're right. You just won't need a dwell meter with the Pertronix kit as the dwell will be set electronically.
I just got 9 mm Ford Racing wires for my wife's '95 Cobra, and they were only $10 more than the Bosch wires. If for nothing more than the look, it was worth $10, plus the wires were numbered, which kept it simple routing the wires back to the distributor cap on the Cobra.
Old Mar 12, 2007 | 04:01 PM
  #23
Hornblower's Avatar
Hornblower
I ♥ Acer
Default RE: Tune up
ORIGINAL: Brandontyler65
ORIGINAL: my77stang
snap-on FTL simply because if something breaks your tracking down a tool truck, but there are sears locations EVERYWHERE.
+ 1 billion kajillion on what everyone else said on doing your own tune ups. for the 225 you will be able to buy GOOD spark plugs, wires, cap/rotor and the petronix unit. most auto part stores have free loaner tools so you dont even need to buy a timing light.
http://cgi.ebay.com/ebaymotors/PERTR...QQcmdZViewItem
or any k-mart for that reason since sears bought k-mart cause malls are losing business so sears is moving out of them according to the store manager at the sears by my house but you can get your craftsmen at k-mart too bad there isn't a blue light special LMAO
I have been wondering if Targetcarries Craftsman tools. I read somewhere that only the Sears stores will carry the Craftsman tools, but I guess I read wrong.
Old Mar 12, 2007 | 04:15 PM
  #24
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Tune up
You can get Craftsman tool at places other than Sears. Here's an online source. I like to go to the store though. That way I can hold it, feel it andplay with it before I buy it. I could spend hours in a big Sears store looking at tools.
http://autobodytoolmart.com/search.a...OVMTC=standard
Old Mar 12, 2007 | 04:27 PM
  #25
grruminator78's Avatar
grruminator78
Default RE: Tune up
like said above do it yourself. The first oil change I ever did myself was on my stang. I didn't know squat about cars to start with. Now I just don't know diddly, at least I know squat. Anyhew tune ups are easy. i just learnt how to do the timing while on the forums.
Plugs easy, wires easy, dizzy cap easy, changing to electonic/getting rid of points easy.
And by the way for 225 you can get a brand new pertronix pug and play billet dizzy with the ignitor II already built in. good luck.
Old Mar 12, 2007 | 10:36 PM
  #26
az1966's Avatar
az1966
Default RE: Tune up
I can go with most of what's been said,,no problem ..the thing I 'd like to know about is check and adjust timing chain and cover?
Old Mar 12, 2007 | 11:05 PM
  #27
my77stang's Avatar
my77stang
Default RE: Tune up
theres no adjustment or anything. if you want to "check" it, you might as well plan on "replacing" it because it WILL be loose. chains stretch over time, and there will be slop in there. a new decent double roller chain isnt too expensive - if your going to replace its worth the extra couple bucks for a stronger unit. also, you'd be able to replace the front main seal since its in the timing cover.
*edit*
kick *** chain:
http://store.summitracing.com/partde...p;autoview=sku
great bang for the buck chain:
stay away from stuff like:
the last chain may look just like the middle chain but the quality differances are significant.
or you could go the route i did.....
Sixx
Oct 5, 2015 07:36 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
Explosive
Oct 2, 2015 07:45 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
