LCA washers?
Old Mar 11, 2007 | 07:06 PM
baddog671's Avatar
baddog671
Default LCA washers?
I was in the garage this morning messing with the couple nuts that are hindering me from making any progress and didnt get much done. I did manage to get the swaybar off which just took a few minutes but now Im down to the rear bolts on the LCA's and the 2 nuts at the end of the strut rods. I got the nut off the driver LCA but when trying to remove the bolt, it just spun and spun. Further investigation reveals what looks like huge washers, one on each side of the mounting area that are just spinning. Is there a special name for these washers? They are about the size of a 50 cent peice and drilled off center. Thanks
Old Mar 11, 2007 | 11:03 PM
baddog671's Avatar
baddog671
Default RE: LCA washers?
Nobody? Come on guys! Well, I got the washers off anyways, along with the bolts. The washers are drilled off center becuase the bolts dont go through a normal hole where it mounts to the frame, it is on a slide. Put the washer on one way and the arm comes closer to the engine(way they were), but Im wondering what would happen if you turned them around, which brings the arm further away from the engine. Playing with it without being bolted up, it looks like it would widen the suspension of the car and tuck it closer to the body?
Any suspension experts in the house?
Old Mar 11, 2007 | 11:17 PM
dnswwood's Avatar
dnswwood
If im not mistaken those are to adjust the camber and caster during alignment
Jeff
Old Mar 11, 2007 | 11:25 PM
Phatboy's Avatar
Phatboy
Those are your camber adjustment washers, you will most deffinitly need to get a professional alignment when you get her all back together. Just eyeballin it wont do, trust me. A little movement goes along way. They wont affect your caster at all, unless you install them wrong.
If you turn it around and move the LCA away from the body your going to get some serious negative camber(way too much for any use), unless mustangs are different from everything else.
Old Mar 12, 2007 | 12:51 AM
baddog671's Avatar
baddog671
I figured they had something to do with the adjustments to the suspension. I dont remember what camber and all that crap is, but the car will be adjusted by a professional. I put them in a baggie of carb cleaner to get most of the junk off and Ill put them back on the best I can later...
Thank you!
Old Mar 12, 2007 | 12:00 PM
dnswwood's Avatar
dnswwood
Opps my mistake you are correct they will not affect the caster,only the camber
Baddog ,camber is the amount your tires lean in and or out from the car .Caster is the same thing only going forward and backward.
Jeff
mtgldr
Feb 3, 2024 09:00 PM
jwog666
Dec 27, 2021 08:09 PM
baddog671
Jul 26, 2016 01:20 PM
UrS4
Sep 30, 2015 10:13 AM
FivePointToTheOh
Sep 15, 2015 08:15 AM
