Oil Change
Old Mar 12, 2007 | 04:45 PM
coda618's Avatar
coda618
Default RE: Oil Change
What's with the jack stands on all four corners? I never jack up the car to change the oil. Just reach under with a wrench and get the drain pan in place.
Old Mar 12, 2007 | 05:18 PM
Soaring's Avatar
Soaring
I ♥ Acer
I think what he meant was in order to thoroughly inspect the undercarriage, you need to jack the car up so you can crawl under there. I never jack it up just to change the oil either.
Old Mar 12, 2007 | 05:26 PM
Gun Jam's Avatar
Gun Jam
I got the ramps from NAPA. I built pre ramps from wood that allow me to drive up on the NAPA ramps it makes the angel a lot less steep which makes driving up easy plus if I dont have the pre ramps the car his the NAPA ramps before the wheels do.
I just make sure its in park and the E brake is set and I have tire chalks under both back wheels.
They were like 40 bucks but give me enough room to inspect the belly and do work I really think they are handy.
Gun
Old Mar 12, 2007 | 06:06 PM
OhioMachIRunner69's Avatar
OhioMachIRunner69
The lube technician couln't get the hood open
...and there is a prime example why you should change your own oil. And $40 to change your oil and you bought your own filter!?!?! Buy yourself a set of ramps; easier than jacking the thing up (I didn't jack mine up to change the oil either, the ramps just make it so easy)...but if you own a classic Mustang you will need a jack and jackstands eventually so they are worth purchasing.
Old Mar 12, 2007 | 06:35 PM
Gun Jam's Avatar
Gun Jam
Here is a good DIY instruction for doing your own oil change.
http://www.tonyrogers.com/humor/changing_oil.htm
Gun
2007StangV6
Jan 28, 2016 06:09 PM
TfcCDR
Sep 14, 2015 12:08 PM
MusicCity615
Sep 12, 2015 07:05 AM
kevsgt
Sep 9, 2015 06:20 AM
