Another shifting question. Second gear is like a kick in the ***
Old 03-13-2007, 12:17 AM
  #21
Jakaru
Jakaru's Avatar
Default RE: Another shifting question. Second gear is like a kick in the ***
I hope these arn't too big. The red is going to be where that hose comes from or in the fist picture where we plugged the intake.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Jakaru is offline
Old 03-13-2007, 12:30 AM
  #22
JMD
JMD's Avatar
Yep,, I think you have it. For sure the red circled plugs. you need to plumb one of these for the rubber tubing. I am pretty sure that is the right tubing, if it continues down to the transmission I will give you a 99.9% that that is the right tube.
Bring the two together and you got it.
JMD is offline
Old 03-13-2007, 12:40 AM
  #23
boeing747arowair
boeing747arowair's Avatar
yup, like i said the modulator is on the passenger side and that seems to be heading that. fix that first before messing with the kickdown!. let us know how it goes
boeing747arowair is offline
Old 03-13-2007, 12:42 AM
  #24
my77stang
my77stang's Avatar
+1, you got it man!
my77stang is offline
Old 03-13-2007, 02:15 AM
  #25
Jakaru
Jakaru's Avatar
Ok so that was the perfect advise. I got a brass fiting for the intake and hooked that hose up to it and now I can't tell when the car shifts. haha. I think my first gear is around 20-25 now instead of 40-50 mph.
Thank you all.
Jakaru is offline
Old 03-13-2007, 02:40 AM
  #26
DenDen
DenDen's Avatar
Had the exact same shifting problem on my c4.ended up being the modulator vacuum tube disconnected.Mine runs straight into the base of my carb.
DenDen is offline
Old 03-13-2007, 02:42 AM
  #27
DenDen
DenDen's Avatar
Kickdown rods are overrated.I havent had one for 3 yrs.When I need a downshift I do it myself.More fun that way.
DenDen is offline
Old 03-13-2007, 02:48 AM
  #28
Jakaru
Jakaru's Avatar
Thats another thing I was wondering. Could I hook it up to the carb instead of the intake? Will it make a difference? Vacume is vacume?
Jakaru is offline
Old 03-13-2007, 02:53 AM
  #29
DenDen
DenDen's Avatar
The only vac tube on the carb you cant use is the on up high by or on the metering block.thats for distributor vacuum.the rest are down low and can be used for other things not requiring high volume such as brake boosters.
DenDen is offline
Old 03-13-2007, 03:02 AM
  #30
Jakaru
Jakaru's Avatar
Well thats easy. it means my dist. is allready using it so I can't accidently take it up haha.
Jakaru is offline
Quick Reply: Another shifting question. Second gear is like a kick in the ***
