Distribution block/Proportioning valve
Old Mar 12, 2007 | 11:20 PM
sxs191's Avatar
sxs191
Default Distribution block/Proportioning valve
I am changing my breakbooster and in the process of taking everythingoff one of the metal tubes that goes from the distrubution block/proportioning valveto the master cylnder broke. Do they make these replacements? Thanks, Scott
Old Mar 12, 2007 | 11:35 PM
mustanglover66's Avatar
mustanglover66
Default RE: Distribution block/Proportioning valve
NPD has them but only in full front set of brake lines. the set includes the lines from the MC to the distubution block and the lines to the front brake hoses all prebent. I got the front to rear line from them they are nice.
Old Mar 13, 2007 | 12:44 PM
sxs191's Avatar
sxs191
I have called a few places and nobody seams to carry just the lines I need between the distribution box and the MC. I really didn't want to spend $45.00 for the whole front kit (because I don't need the whole thing) but it looks likeI might have to just for those small lines. UGH!
Old Mar 13, 2007 | 01:08 PM
gothand's Avatar
gothand
Go to a good auto parts stores with your old lines so you can match up the fittings. Most good stores sell pre-flared lines and adaptor lines. Even if they don't have excactly what you need, figure out the sizes then go online and order them. Pick up a $10 bender and have at it.
Old Mar 13, 2007 | 01:12 PM
Soaring's Avatar
Soaring
I ♥ Acer
With a flaring tool and a bender, you can fabricate any line. First, go to a parts store with your old line and see if they can replicate it for you.
Old Mar 13, 2007 | 01:22 PM
sxs191's Avatar
sxs191
Great, Thanks for the info.
Old Mar 13, 2007 | 01:24 PM
sxs191's Avatar
sxs191
Can I pick up this flaring tool and pipe bender at any auto location? Do they come in packs like the tap and die sets?
Old Mar 13, 2007 | 01:28 PM
gothand's Avatar
gothand
You can pick up both of those at most auto parts stores. It is hard to go wrong with a bender, but the double flare kit gives better results if you buy a nicer $$$ one. FWIW, if you go this route you'll be into it for at least as much or more than if you bought the pre-fab line kit and tossed the ones you didn't need.
Old Mar 13, 2007 | 02:55 PM
sxs191's Avatar
sxs191
Does anyone know whatsize break lines (width) I need or arethey standard size?
Old Mar 13, 2007 | 03:50 PM
Soaring's Avatar
Soaring
I ♥ Acer
Your brake lines are 3/16" OD
GimpyHSHS
19
Dec 19, 2023 01:12 PM
mrtrodonet
Sep 19, 2020 03:12 PM
svfetter
Oct 5, 2015 11:39 AM
69Volunteer
Sep 30, 2015 10:39 AM
lmurf60
Sep 24, 2015 10:07 PM
