proportion valve
Old Mar 13, 2007 | 05:16 PM
eZ's Avatar
eZ
Default proportion valve
does it matter where on the line going to the rear brakes you put it? i have my rear line leaving my master cylinder and going directly into the proportioning valve. or should it be mounted towards the rear of the car?
[/align]
Old Mar 13, 2007 | 05:47 PM
gothand's Avatar
gothand
Default RE: proportion valve
Keep it up under the hood next to your MC, distribution block, etc. Sounds like you have it right.
Old Mar 13, 2007 | 08:36 PM
cole18cars's Avatar
cole18cars
With a dual M.C. do you still need the distribution block? And the proportioning valve goes on the rear brake line?
Old Mar 13, 2007 | 09:04 PM
Soaring's Avatar
Soaring
I ♥ Acer
Never install a proportioning valve in any way that would affect the front brakes. The result would be to make your car rear-biased before you could say “brake pressure regulating valves.†Front brake-line pressure should always be left alone—only the rear pressures should be considered for proportioning. Get an adjustable valve, and mount it right below your MC.
Old Mar 13, 2007 | 09:08 PM
baddog671's Avatar
baddog671
ORIGINAL: Soaring
Glen, what if your running the Granada breaks up front? All the kits and how-to's ive seen use them?
Old Mar 13, 2007 | 09:09 PM
connor90's Avatar
connor90
if you have a distrabution block you are supposed to put the proportioning valve after the dist. block. if you dont have one then dont worry about it.
Old Mar 13, 2007 | 09:11 PM
cole18cars's Avatar
cole18cars
No distribution block, right
Old Mar 13, 2007 | 10:27 PM
gothand's Avatar
gothand
To clear things up, the 64-66 distribution block is merely a "tee" to split the pressure to the front brake lines. The rear is split on the axle at the rubber line. Later model Fords use a distribution block which has a built-in proportioning valve for the rear valve, a tee for the front and a pressure switch that'll show loss of pressure in one of the lines.
If you're doing the Granada swap with a dual reservoir MC, run the rear line on the MC to the "tee" for the front brake lines. For the rear, do like Soaring said, run a single line from the front hole of the MC to an adjustable pressure valve then to the line to the rear.
You can try picking up a distribution block from a Granada and plumb straight into it. Go to Mustang Steve's FAQ and you'll see all the info you need.
[edit] Soaring's point should be emphasized, you never want the rear wheels to lock up before the front ... unless you like the rear coming around on you.
Old Mar 13, 2007 | 10:39 PM
Soaring's Avatar
Soaring
I ♥ Acer
Thanks for clearing that up Jeff. I have had the rear of some cars lock up before the front, and they came around on me and damn near turned me over before I could get them stopped. And that was usually in the ditch. I haven't had that problem with my 65 because I have the rear brakes a tad looser than the front shoes. I really need to get disks for the front. Maybe next month...........
Old Mar 13, 2007 | 11:30 PM
baddog671's Avatar
baddog671
Ok, so for my 67 with Granada swap and dual MC, the rear hole in the MC runs to the T in the distribution for the front brakes, and the front hole runs to the por valve, then back to the axle?
