Transmission leake??
Old Mar 14, 2007 | 07:21 PM
ndnboy's Avatar
ndnboy
Default Transmission leake??
I have a small/slow leake out from around the trans oil pan. Mechanic said it looks like it could be a combo from shift shaft seal and/or the valve modulator. He said if I could deal with the cleanup to wait until i am ready to work/rebuild tranny and save myself the quick fix cost.
the transmission shifts fine and as far as i can tell everything is ok.
should i look at the complete rebuild or take his advice and wait? are these leakes NORMAL for our rides?? i have never worked on the tranny, is it something a NEWBIE could undertake?
Thanks
Old Mar 14, 2007 | 07:42 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Transmission leake??
I don't understand why a mechanic would tell you that something inside the transmission is causing the leak on the outside. If I were you, I'd just replace the pan gasket, fill her back up and go on.
Old Mar 14, 2007 | 07:45 PM
eholzer07's Avatar
eholzer07
Make sure you dont evertighten those bolts around the pan. It could actually make the situation worse. Torque them with a torque wrench to get the right amount or ull end up with a leak worse than you already have. But id just say go with a new gasket
Old Mar 14, 2007 | 07:55 PM
ndnboy's Avatar
ndnboy
I had recently changed the trans fluid/filter and gasket. He fixed a leake around the dipstick ring and checked my work on the gasket (to make sure i did not over do it). he did not say it was an inside issue but that he would have to drop the tranny to get to the shift shaft seal and that the cost of his labor may be something to put off untill i want the whole thing worked on. he could not say anything else would not leake vs guaranteeing the work on a complete job???
Old Mar 14, 2007 | 08:39 PM
dnswwood's Avatar
dnswwood
Is it a C4? if so it may be the vent on top leaking and making it look like the pan is leaking.
Jeff
Old Mar 14, 2007 | 09:09 PM
ndnboy's Avatar
ndnboy
yeah, its a c4.
I think the modualtor is a quick try at a fix, bolt on ibelieve (for that matter maybe look at replacing the pan asket AGAIN). The seal was my bigger concern, dont know if i trust myself to remove the tranny if needed to get to it....
Old Mar 14, 2007 | 09:10 PM
my67pony's Avatar
my67pony
I second dssnwwood. Thats where I found my leak.
Old Mar 14, 2007 | 09:11 PM
ndnboy's Avatar
ndnboy
how do you get to the vent, is there a gasket there as well?
Old Mar 14, 2007 | 10:07 PM
palerider's Avatar
palerider
I've got a leak in mine also. Thought it was dipstick ring- but not that I'm ready this post maybe it's - I'll have to get under and look at it - is this an easy fix?
4cylinderplus2
Oct 9, 2020 07:45 PM
jerrytubes
Oct 23, 2015 12:11 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
wraith777
Sep 28, 2015 10:49 AM
