windshield wiper motor
Old Mar 20, 2007 | 12:18 PM
BronzeBondo's Avatar
BronzeBondo
Default windshield wiper motor
hello everyone,
windshield wipers in 65 coupe dont work:
where is the motor located and what else should i check?
its not working at all. no power whatsoever.
Old Mar 20, 2007 | 12:37 PM
gjz30075's Avatar
gjz30075
Default RE: windshield wiper motor
The motor is located up under the dash next to the pedal hanger. Find the connection between the wiper motor harness and the main harness and disconnect it. There is a procedure in the manual about where to apply 12v to determine whether or not its working.
Old Mar 20, 2007 | 01:13 PM
BronzeBondo
Is there a website i could go to where id be able to view the manual?
Old Mar 20, 2007 | 06:33 PM
gjz30075's Avatar
gjz30075
Here's a good start:
http://www.hammar.dyndns.org/wiring.htm
Old Mar 20, 2007 | 09:57 PM
kalli's Avatar
kalli
i'll check what I have in the manual. might be able to scan something.
But as gjz says, disconnect the cable attached to the wiper motor and clean both sides. then try again.
I had all sorts of issues with mine and it was just a bad connection there.
kalli
Old Mar 23, 2007 | 04:58 PM
BronzeBondo
thank you fellas for the info
Old Mar 23, 2007 | 08:37 PM
Soaring's Avatar
Soaring
I ♥ Acer
Have you checked the fuse?
firehorse02
Nov 16, 2015 11:28 AM
UrS4
Oct 3, 2015 06:23 AM
Explosive
Oct 2, 2015 07:45 AM
Drastang
Sep 30, 2015 03:48 AM
logan409
Sep 26, 2015 07:43 PM
