resistor wire delete...again
Old Mar 21, 2007 | 08:05 PM
pinboy122's Avatar
pinboy122
Default resistor wire delete...again
hey guys sorry to re-hash covered ground,but im trying to get the stang ready for the new engine.its a 65 289 4-speed car.im looking for the link for directions to bypass the pink resistor wire anf the links in the faq's arnt working for me.any help appreciated thanks!!!
Old Mar 21, 2007 | 08:11 PM
mikethebike's Avatar
mikethebike
Default RE: resistor wire delete...again
I assume you are no longer running the points ignition? If you are and you bypass the wire you will 1/2 life or worse to your points.All you should need to do is look at the schematic and see where to jumper on the switch to not disconnect the straight non-resistor wire.
Old Mar 21, 2007 | 08:23 PM
pinboy122's Avatar
pinboy122
no points here.im running a msd 6al +distributer.i have no way to test the wires on the back of the ignition switch for12v key on because im waiting for the ups guy to drop off the rest of my stuff(soloniod,battery cables etc....)
Old Mar 21, 2007 | 08:27 PM
Soaring's Avatar
Soaring
I ♥ Acer
Here is the wiring diagrams. See which one becomes the pink resistor. Best I recall it is blue/black.
http://www.midlife66.com/wiring/wiring.html
Old Mar 21, 2007 | 10:06 PM
pinboy122's Avatar
pinboy122
ok,i think i got it.i have no blue/black wire but i think i can cut and splice between the switch and pink wire and run a new wire out to the msd box.thanks for the help
Old Mar 21, 2007 | 11:39 PM
Colorado_Mustang's Avatar
Colorado_Mustang
The MSD box doesn't care if you have a resistor wire or not. It's only looking for the signal. The wire between your MSD box and its coil should not be a resistor wire, however.
jwog666
Dec 27, 2021 08:09 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Dathan
Oct 5, 2015 05:52 AM
lmurf60
Sep 24, 2015 10:07 PM
